MainDictionary 属性 (ActiveX)
2024-5-18 18:33| 发布者: admin| 查看: 750| 评论: 0|原作者: admin|来自: AutoCAD
指定用于拼写检查的当前词典。
object.MainDictionary
类型:PreferencesFiles
此属性应用于的对象。
只读:不
类型:字符串
要使用的拼写检查词典。
Sub Example_MainDictionary()
    ' MainDictionary. It then changes the value, and finally
    Dim currMainDictionary As String
    Dim newMainDictionary As String
    Set preferences = ThisDrawing.Application.preferences
    ' Retrieve the current MainDictionary value
    currMainDictionary = preferences.Files.MainDictionary
    MsgBox "The current value for MainDictionary is " & currMainDictionary, vbInformation, "MainDictionary Example"
    ' Change the value for MainDictionary
    newMainDictionary = "TestMainDictionary"
    preferences.Files.MainDictionary = newMainDictionary
    MsgBox "The new value for MainDictionary is " & newMainDictionary, vbInformation, "MainDictionary Example"
    ' Reset MainDictionary to its original value
    preferences.Files.MainDictionary = currMainDictionary
    MsgBox "The MainDictionary value is reset to " & currMainDictionary, vbInformation, "MainDictionary Example"
(defun c:Example_MainDictionary()
    ;; MainDictionary. It then changes the value, and finally
    ;; Retrieve the current MainDictionary value
    (setq currMainDictionary (vla-get-MainDictionary (vla-get-Files preferences)))
    (alert (strcat "The current value for MainDictionary is " currMainDictionary))
    ;; Change the value for MainDictionary
    (setq newMainDictionary "TestMainDictionary")
    (vla-put-MainDictionary (vla-get-Files preferences) newMainDictionary)
    (alert (strcat "The new value for MainDictionary is " newMainDictionary))
    ;; Reset MainDictionary to its original value
    (vla-put-MainDictionary (vla-get-Files preferences) currMainDictionary)
    (alert (strcat "The MainDictionary value is reset to " currMainDictionary))
GMT+8, 2026-10-27 07:52
