Lock 属性 (ActiveX)
2024-5-18 18:33| 发布者: admin| 查看: 866| 评论: 0|原作者: admin|来自: AutoCAD
Lock 属性 (ActiveX)
锁定或解锁图层。
object.Lock
类型:图层
此属性应用于的对象。
只读:不
类型:布尔
  • True:图层已锁定。
  • False:图层已解锁。
您无法编辑锁定图层上的对象;但是,如果该层打开并解冻,它们仍然可见。您可以激活锁定图层,并可以向其添加对象。还可以将对象捕捉模式应用于锁定图层上的对象。您可以冻结和关闭锁定的图层,并更改其关联的颜色。
当您想要编辑与特定图层关联的对象,但又想查看其他图层上的对象时,锁定非常有用。
Sub Example_Lock()
    ' This example creates a new layer called "Lock".
    ' It then displays the status of the Lock property
    ' for the new layer, toggles the status of the
    ' Lock property, and again displays its status.
    ' After running this example, you can check the layer
    ' control on the Object Properties tool bar. It will
    ' show the new layer and the latest Lock status.
    Dim layerObj As AcadLayer
    ' Create the new layer
    Set layerObj = ThisDrawing.Layers.Add("Lock")
    ' Display the Lock status of the new layer
    GoSub DISPLAYSTATUS
    ' Toggle the status of the Lock property for the layer
    layerObj.Lock = Not (layerObj.Lock)
    GoSub DISPLAYSTATUS
    Exit Sub
DISPLAYSTATUS:
    If layerObj.Lock Then
        MsgBox "Layer " & layerObj.Name & " is locked.", , "Lock Example"
    Else
        MsgBox "Layer " & layerObj.Name & " is unlocked.", , "Lock Example"
    End If
    Return
(defun c:Example_Lock()
    ;; This example creates a new layer called "Lock".
    ;; It then displays the status of the Lock property
    ;; for the new layer, toggles the status of the
    ;; Lock property, and again displays its status.
    ;; After running this example, you can check the layer
    ;; control on the Object Properties tool bar. It will
    ;; show the new layer and the latest Lock status.
    ;; Create the new layer
    (setq layerObj (vla-Add (vla-get-Layers doc) "Lock"))
    ;; Display the Lock status of the new layer
    (if (= (vla-get-Lock layerObj) :vlax-true)
        (alert (strcat "Layer " (vla-get-Name layerObj) " is locked."))
        (alert (strcat "Layer " (vla-get-Name layerObj) " is unlocked."))
    ;; Toggle the status of the Lock property for the layer
    (vla-put-Lock layerObj (if (= (vla-get-Lock layerObj) :vlax-true) :vlax-false :vlax-true))
GMT+8, 2026-11-30 15:08
