LineweightDisplay 属性 (ActiveX)
2024-5-18 18:33| 发布者: admin| 查看: 675| 评论: 0|原作者: admin|来自: AutoCAD
指定是否在绘图的模型空间中显示线宽。
object.LineweightDisplay
类型:DatabasePreferences
此属性应用于的对象。
只读:不
类型:布尔
  • True:线宽显示在模型空间中。
  • False:线宽不显示在模型空间中。
此属性的初始值为 。True
AutoCAD 再生时间随着线宽的增加而增加,线宽由多个像素表示。将此特性设置为在使用大线宽时 AutoCAD 性能降低的情况。False
Sub Example_LineweightDisplay()
    ' This example reads and modifies the preference value that controls
    ' whether symbol names may include extended character sets, or more
    ' than 31 characters.
    ' When finished, this example resets the preference value back to
    ' its original value.
    Dim ACADPref As AcadDatabasePreferences
    ' Get the user preferences object
    Set ACADPref = ThisDrawing.preferences
    originalValue = ACADPref.LineWeightDisplay
    MsgBox "The LineweightDisplay preference is set to: " & originalValue
    ' Modify the LineweightDisplay preference by toggling the value
    ACADPref.LineWeightDisplay = Not (ACADPref.LineWeightDisplay)
    newValue = ACADPref.LineWeightDisplay
    MsgBox "The LineweightDisplay preference has been set to: " & newValue
    '         this preference in effect
    ACADPref.LineWeightDisplay = originalValue
    MsgBox "The LineweightDisplay preference was reset back to: " & originalValue
(defun c:Example_LineweightDisplay()
    ;; This example reads and modifies the preference value that controls
    ;; the display of lineweights in the drawing window.
    ;; When finished, this example resets the preference value back to
    ;; its original value.
    (setq preferences (vla-get-Preferences doc))
    (setq originalValue (vla-get-LineWeightDisplay preferences))
    (alert (strcat "The LineweightDisplay preference is set to: " (if (= originalValue :vlax-true) "True" "False")))
    ;; Modify the LineweightDisplay preference by toggling the value
    (vla-put-LineWeightDisplay preferences (if (= originalValue :vlax-true) :vlax-false :vlax-true))
    (setq newValue (vla-get-LineWeightDisplay preferences))
    (alert (strcat "The LineweightDisplay preference has been set to: " (if (= newValue :vlax-true) "True" "False")))
    ;;         this preference in effect
    (vla-put-LineWeightDisplay preferences originalValue)
    (alert (strcat "The LineweightDisplay preference was reset back to: " (if (= originalValue :vlax-true) "True" "False")))
GMT+8, 2026-10-28 08:17
