LinetypeScale 属性 (ActiveX)
2024-5-18 18:33| 发布者: admin| 查看: 952| 评论: 0|原作者: admin|来自: AutoCAD
指定对象的线型比例。
object.LinetypeScale
类型:所有绘图对象、AttributeReference、Group、SubDMeshEdge、SubDMeshFace、SubDMeshVertex、SubEntity、SubEntSolidEdge、SubEntSolidFace、SubEntSolidNode、SubEntSolidVertex
此属性应用于的对象。
只读:不;只写对象除外Group
类型:双
此值必须为正实数。默认值为 1.0。
对象的线型比例指定每个绘图单位的虚线点线型的相对长度。
  • :线型比例 = 1.0
  • :线型刻度 = 0.5
  • :线型刻度 = 0.25
Sub Example_LinetypeScale()
    ' This example creates a line and finds the linetype scale
    ' for the line. It then changes the linetype scale, and finally
    ' resets the linetype scale back to the original value.
    Dim lineObj As AcadLine
    Dim currLTScale As Double
    ' Create a Line object in model space
    startPoint(0) = 2#: startPoint(1) = 2#: startPoint(2) = 0#
    endPoint(0) = 4#: endPoint(1) = 4#: endPoint(2) = 0#
    lineObj.Update
    currLTScale = lineObj.LinetypeScale
    MsgBox "The linetype scale for the line is: " & lineObj.LinetypeScale, vbInformation, "Linetypes Example"
    ' Set the linetype scale of a Line to .5
    lineObj.LinetypeScale = 0.5
    lineObj.Update
    MsgBox "The new linetype scale for the line is: " & lineObj.LinetypeScale, vbInformation, "Linetypes Example"
    ' Reset the linetype scale of a Line to what is was before
    lineObj.LinetypeScale = currLTScale
    lineObj.Update
    MsgBox "The linetype scale for the line is reset to: " & lineObj.LinetypeScale, vbInformation, "Linetypes Example"
(defun c:Example_LinetypeScale()
    ;; This example creates a line and finds the linetype scale
    ;; for the line. It then changes the linetype scale, and finally
    ;; resets the linetype scale back to the original value.
    ;; Create a Line object in model space
    (setq startPoint (vlax-3d-point 2 2 0)
          endPoint (vlax-3d-point 4 4 0))
    (vla-Update lineObj)
    (setq currLTScale (vla-get-LinetypeScale lineObj))
    (alert (strcat "The linetype scale for the line is: " (rtos currLTScale 2)))
    ;; Set the linetype scale of a Line to .5
    (vla-put-LinetypeScale lineObj 0.5)
    (alert (strcat "The new linetype scale for the line is: " (rtos (vla-get-LinetypeScale lineObj) 2)))
    ;; Reset the linetype scale of a Line to what is was before
    (vla-put-LinetypeScale lineObj currLTScale)
    (alert (strcat "The linetype scale for the line is reset to: " (rtos (vla-get-LinetypeScale lineObj) 2)))
GMT+8, 2026-12-1 04:22
