LineSpacingStyle 属性 (ActiveX)
2024-5-18 18:33| 发布者: admin| 查看: 797| 评论: 0|原作者: admin|来自: AutoCAD
指定 MText 对象的行距样式。
object.LineSpacingStyle
类型:GeoPositionMarker、MText
此属性应用于的对象。
只读:不
类型:枚举acLineSpacingStyle
  • acLineSpacingStyleAtLeast
  • acLineSpacingStyleExactly
该设置允许根据文本行中最大字符的高度自动调整不同文本行之间的间距。该设置强制对象中所有行的行距大小相同,而不考虑格式覆盖。acLineSpacingStyleAtLeastacLineSpacingStyleExactlyMText
Sub Example_LineSpacingFactor()
    ' This example creates an MText object in model space
    ' and then finds the LineSpacingFactor for the object.
    Dim MTextObj As AcadMText
    Dim corner(0 To 2) As Double
    Dim width As Double
    Dim text As String
    corner(0) = 0#: corner(1) = 10#: corner(2) = 0#
    width = 10
    text = "This is the text String for the mtext Object"
    ' Creates the MText Object
    Set MTextObj = ThisDrawing.ModelSpace.AddMText(corner, width, text)
    ZoomAll
    ' Find the current LineSpacingFactor
    Dim currFactor As Double
    currFactor = MTextObj.LineSpacingFactor
    MsgBox "The LineSpacingFactor for the MText object is: " & currFactor
    ' Change the LineSpacingFactor
    MTextObj.LineSpacingFactor = 4
    MsgBox "The LineSpacingFactor for the MText object is: " & MTextObj.LineSpacingFactor
    ' Reset the LineSpacingFactor
    MTextObj.LineSpacingFactor = currFactor
(defun c:Example_LineSpacingFactor()
    ;; This example creates an MText object in model space
    ;; and then finds the LineSpacingFactor for the object.
    (setq corner (vlax-3d-point 0 10 0)
          width 10
          text "This is the text String for the mtext Object")
    ;; Creates the MText Object
    (setq MTextObj (vla-AddMText modelSpace corner width text))
    (vla-ZoomAll acadObj)
    ;; Find the current LineSpacingFactor
    (setq currFactor (vla-get-LineSpacingFactor MTextObj))
    (alert (strcat "The LineSpacingFactor for the MText object is: " (rtos currFactor 2)))
    ;; Change the LineSpacingFactor
    (vla-put-LineSpacingFactor MTextObj 0.7)
    (alert (strcat "The LineSpacingFactor for the MText object is: " (rtos (vla-get-LineSpacingFactor MTextObj) 2)))
    ;; Reset the LineSpacingFactor
    (vla-put-LineSpacingFactor MTextObj currFactor)
GMT+8, 2026-10-27 20:50
