LayoutCrosshairColor 属性 (ActiveX)
2024-5-18 18:33| 发布者: admin| 查看: 889| 评论: 0|原作者: admin|来自: AutoCAD
指定图纸空间布局的十字准线和文本的颜色。
object.LayoutCrosshairColor
类型:首选项显示
此属性应用于的对象。
只读:不
类型:OLE_COLOR(常量)
  • vbBlack
  • vbRed
  • vbYellow
  • vbGreen
  • vbCyan
  • vbBlue
  • vbMagenta
  • vbWhite
此属性的初始值是 Windows 标准文本颜色。
若要指定模型空间布局的十字线颜色,请使用该属性。ModelCrosshairColor
Sub Example_LayoutCrosshairColor()
    ' This example reads and modifies the preference value that controls
    ' the color of the crosshairs and text for paper space layouts.
    ' When finished, this example resets the preference value back to
    ' its original value.
    Dim ACADPref As AcadPreferencesDisplay
    ' Get the display preferences object
    Set ACADPref = ThisDrawing.Application.Preferences.Display
    ' Switch to paper space to view this change
    ThisDrawing.ActiveSpace = acPaperSpace
    originalValue = ACADPref.LayoutCrosshairColor
    MsgBox "The LayoutCrosshairColor preference is: " & originalValue
    ' Modify the LayoutCrosshairColor preference by making it red
    ACADPref.LayoutCrosshairColor = vbRed
    newValue = ACADPref.LayoutCrosshairColor
    MsgBox "The LayoutCrosshairColor preference has been set to: " & newValue
    '         this preference in effect
    ACADPref.LayoutCrosshairColor = originalValue
    MsgBox "The LayoutCrosshairColor preference was reset back to: " & originalValue
(defun c:Example_LayoutCrosshairColor()
    ;; This example reads and modifies the preference value that controls
    ;; the color of the crosshairs and text for paper space layouts.
    ;; When finished, this example resets the preference value back to
    ;; its original value.
    ;; Switch to paper space to view this change
    (vla-put-ActiveSpace doc acPaperSpace)
    (setq originalValue (vlax-variant-change-type (vla-get-LayoutCrosshairColor (vla-get-Display preferences)) vlax-vbLong))
    (alert (strcat "The LayoutCrosshairColor preference is: " (itoa (vlax-variant-value originalValue))))
    ;; Modify the LayoutCrosshairColor preference by making it red
    (vla-put-LayoutCrosshairColor (vla-get-Display preferences) (vlax-make-variant acRed 19))
    (setq newValue (vlax-variant-change-type (vla-get-LayoutCrosshairColor (vla-get-Display preferences)) vlax-vbLong))
    (alert (strcat "The LayoutCrosshairColor preference has been set to: " (itoa (vlax-variant-value newValue))))
    ;;         this preference in effect
    (vla-put-LayoutCrosshairColor (vla-get-Display preferences) (vlax-variant-change-type originalValue 19))
    (alert (strcat "The LayoutCrosshairColor preference was reset back to: " (itoa (vlax-variant-value originalValue))))
GMT+8, 2026-11-1 17:47
