LayoutCreateViewport 属性 (ActiveX)
2024-5-18 18:33| 发布者: admin| 查看: 853| 评论: 0|原作者: admin|来自: AutoCAD
切换新布局的视口的自动创建。
object.LayoutCreateViewport
类型:首选项显示
此属性应用于的对象。
只读:不
类型:布尔
  • True:为新布局创建视口。
  • False:不会为新布局创建视口。
此属性的初始值为 。True
Sub Example_LayoutCreateViewport()
    ' This example reads and modifies the preference value that controls
    ' the automatic creation of a viewport for new layouts. When finished, this example
    ' resets the preference value back to its original value.
    Dim ACADPref As AcadPreferencesDisplay
    ' Get the display preferences object
    Set ACADPref = ThisDrawing.Application.preferences.DISPLAY
    originalValue = ACADPref.LayoutCreateViewport
    MsgBox "The LayoutCreateViewport preference is set to: " & originalValue
    ' Modify the LayoutCreateViewport preference by toggling the value
    ACADPref.LayoutCreateViewport = Not (originalValue)
    newValue = ACADPref.LayoutCreateViewport
    MsgBox "The LayoutCreateViewport preference has been set to: " & newValue
    '         this preference in effect
    ACADPref.LayoutCreateViewport = originalValue
    MsgBox "The LayoutCreateViewport preference was reset back to: " & originalValue
(defun c:Example_LayoutCreateViewport()
    ;; This example reads and modifies the preference value that controls
    ;; the automatic creation of a viewport for new layouts. When finished, this example
    ;; resets the preference value back to its original value.
    (setq originalValue (vla-get-LayoutCreateViewport (vla-get-Display preferences)))
    (alert (strcat "The LayoutCreateViewport preference is set to: " (if (= originalValue :vlax-true) "True"  "False")))
    ;; Modify the LayoutCreateViewport preference by toggling the value
    (vla-put-LayoutCreateViewport (vla-get-Display preferences) (if (= originalValue :vlax-true) :vlax-false :vlax-true))
    (setq newValue (vla-get-LayoutCreateViewport (vla-get-Display preferences)))
    (alert (strcat "The LayoutCreateViewport preference has been set to: " (if (= newValue :vlax-true) "True"  "False")))
    ;;         this preference in effect
    (vla-put-LayoutCreateViewport (vla-get-Display preferences) originalValue)
    (alert (strcat "The LayoutCreateViewport preference was reset back to: " (if (= originalValue :vlax-true) "True"  "False")))
GMT+8, 2026-11-29 11:13
