Layers 属性 (ActiveX)
2024-5-18 18:33| 发布者: admin| 查看: 749| 评论: 0|原作者: admin|来自: AutoCAD
Layers 属性 (ActiveX)
获取文档的 Layers 集合。
object.Layers
类型:数据库、文档
此属性应用于的对象。
只读:是的
类型: 图层
文档的 Layers 集合。
Sub Example_Layers()
    ' This example finds the current Layers collection and
    ' adds a new layer to that collection.
    Dim layerColl As AcadLayers
    Set layerColl = ThisDrawing.Layers
    ' Create a dimension style named "TEST" in current drawing
    Dim testlayer As AcadLayer
    Set testlayer = layerColl.Add("TEST")
    MsgBox "A new layer called " & testlayer.name & " has been added to the Layers collection.", vbInformation, "Layers Example"
(defun c:Example_Layers()
    ;; This example finds the current Layers collection and
    ;; adds a new layer to that collection.
    (setq layerColl (vla-get-Layers doc))
    ;; Create a dimension style named "TEST" in current drawing
    (setq testlayer (vla-Add layerColl "TEST"))
    (alert (strcat "A new layer called " (vla-get-Name testlayer) " has been added to the Layers collection."))
GMT+8, 2026-11-5 01:13
