LastHeight 属性 (ActiveX)
指定上次使用的文本高度。 支持的平台:仅限 Windows 属性值只读:不 类型:双 用于文本样式的最后一个文本高度。 言论没有其他评论。 例子VBA: Sub Example_LastHeight()
' This example finds the current value for LastHeight.
' It then changes that value, and resets it again.
Dim txtStyleObj As AcadTextStyle
Set txtStyleObj = ThisDrawing.ActiveTextStyle
' Set and retrieve the LastHeight property
Dim currHeight As Double
Dim newHeight As Double
' Retrieve current LastHeight property
currHeight = txtStyleObj.lastHeight
MsgBox "The current value for LastHeight is " & txtStyleObj.lastHeight, , "LastHeight Example"
' Set LastHeight to a new value
txtStyleObj.lastHeight = 4#
' Retrieve the current LastHeight value
newHeight = txtStyleObj.lastHeight
MsgBox "The new value for LastHeight is " & txtStyleObj.lastHeight, , "LastHeight Example"
' Finally reset LastHeight to its default value
txtStyleObj.lastHeight = currHeight
MsgBox "The value for LastHeight has been reset to " & txtStyleObj.lastHeight, , "LastHeight Example"
可视化 LISP: (vl-load-com)
(defun c:Example_LastHeight()
;; This example finds the current value for LastHeight.
;; It then changes that value, and resets it again.
(setq txtStyleObj (vla-get-ActiveTextStyle doc))
;; Set and retrieve the LastHeight property
;; Retrieve current LastHeight property
(setq currHeight (vla-get-LastHeight txtStyleObj))
(alert (strcat "The current value for LastHeight is " (rtos currHeight 2)))
;; Set LastHeight to a new value
(vla-put-LastHeight txtStyleObj 4)
;; Retrieve the current LastHeight value
(setq newHeight (vla-get-LastHeight txtStyleObj))
(alert (strcat "The new value for LastHeight is " (rtos newHeight 2)))
;; Finally reset LastHeight to its default value
(vla-put-LastHeight txtStyleObj currHeight)
(alert (strcat "The value for LastHeight has been reset to " (rtos currHeight 2)))
GMT+8, 2026-10-26 18:19
