LandingGap 属性 (ActiveX)
2024-5-18 18:33| 发布者: admin| 查看: 797| 评论: 0|原作者: admin|来自: AutoCAD
指定文本着陆间隙。
object.LandingGap
类型:GeoPositionMarker、MLeader、MLeaderStyle
此属性应用于的对象。
只读:不
类型:双
文本着陆间隙。
Sub Example_LeaderLine()
    Dim oML As AcadMLeader
    Dim points(0 To 5) As Double
    points(0) = 1: points(1) = 1: points(2) = 0
    points(3) = 4: points(4) = 4: points(5) = 0
    Dim i As Long
    Set oML = ThisDrawing.ModelSpace.AddMLeader(points, i)
    Dim r As Long
    r = oML.AddLeader()
    points(4) = 10
    Call oML.AddLeaderLine(r, points)
    MsgBox "LeaderCount = " & oML.LeaderCount
    ZoomExtents
(defun c:Example_LeaderLine()
    (setq points (vlax-make-safearray vlax-vbDouble '(0 . 5)))
    (vlax-safearray-fill points '(1 1 0
                                  4 4 0
    (setq i 0)
    (setq oML (vla-AddMLeader modelSpace points i))
    (setq r (vla-AddLeader oML))
    (vlax-safearray-put-element points 4 10)
    (vla-AddLeaderLine oML r points)
    (alert (strcat "LeaderCount = " (itoa (vla-get-LeaderCount oML))))
    (vla-ZoomExtents acadObj)
GMT+8, 2026-10-24 08:56
