Label 属性 (ActiveX)
指定菜单项在用户面前显示的内容和格式。 支持的平台:仅限 Windows 属性值只读:不 类型:字符串 弹出菜单项的标签。 言论与属性不同,此属性可以包含 DIESEL 字符串表达式,这些表达式在每次显示标签时都会有条件地更改标签。Caption 例子VBA: Sub Example_Label()
' This example iterates through the first menu in the menu bar
' and displays the label for each menu item.
Dim menuItem As AcadPopupMenuItem
Dim menuLabel As String
menuLabel = ""
For Each menuItem In ThisDrawing.Application.MenuBar.Item(0)
menuLabel = menuLabel & menuItem.Label & vbCrLf
Next menuItem
MsgBox menuLabel
可视化 LISP: (vl-load-com)
(defun c:Example_Label()
;; This example iterates through the first menu in the menu bar
;; and displays the label for each menu item.
(setq menuLabel "")
(vlax-for menuItem (vla-Item (vla-get-MenuBar acadObj) 0)
(setq menuLabel (strcat menuLabel (vla-get-Label menuItem) "\n"))
(alert menuLabel)
GMT+8, 2026-10-31 14:07
