IsQuiescent 属性 (ActiveX)
2024-5-18 18:33| 发布者: admin| 查看: 835| 评论: 0|原作者: admin|来自: AutoCAD
检查AutoCAD是否处于空闲状态并准备好接受来自进程外应用程序的自动化调用。
object.IsQuiescent
类型: 状态
此属性应用于的对象。
只读:是的
类型:布尔
  • True:AutoCAD 处于空闲状态。
  • False:AutoCAD 正忙。
Sub Example_IsQuiescent()
    ' This example gets the acadState object and checks to see whether
    ' AutoCAD is in a quiescent state.
    Dim State As AcadState
    Set State = GetAcadState
    If State.IsQuiescent Then
        MsgBox "AutoCAD is quiescent."
    Else
        MsgBox "AutoCAD is not quiescent."
    End If
(defun c:Example_IsQuiescent()
    ;; This example gets the acadState object and checks to see if
    ;; AutoCAD is in a quiescent state.
    (setq State (vla-GetAcadState acadObj))
    (if (= (vla-get-IsQuiescent State) :vlax-true)
        (alert "AutoCAD is quiescent.")
        (alert "AutoCAD is not quiescent.")
GMT+8, 2026-11-30 11:03
