IsPlanar 属性 (ActiveX)
2024-5-18 18:33| 发布者: admin| 查看: 792| 评论: 0|原作者: admin|来自: AutoCAD
确定给定样条是否为平面样条。
object.IsPlanar
类型:样条曲线
此属性应用于的对象。
只读:是的
类型:布尔
  • True:样条曲线是平面的。
  • False:样条曲线不是平面的。
Sub Example_IsPlanar()
    ' This example creates a Spline object in model space and
    ' determines whether the Spline is planar
    Dim splineObj As AcadSpline
    Dim startTan(0 To 2) As Double, endTan(0 To 2) As Double
    Dim fitPoints(0 To 8) As Double
    Dim UserMessage As String
    ' Define the Spline object
    startTan(0) = 0.5: startTan(1) = 0.5: startTan(2) = 0
    endTan(0) = 0.5: endTan(1) = 0.5: endTan(2) = 0
    fitPoints(0) = 0: fitPoints(1) = 0: fitPoints(2) = 0: fitPoints(3) = 5
    fitPoints(4) = 5: fitPoints(5) = 0: fitPoints(6) = 10: fitPoints(7) = 0: fitPoints(8) = 0
    ' Create new Spline object
    Set splineObj = ThisDrawing.ModelSpace.AddSpline(fitPoints, startTan, endTan)
    ' Display whether or not new Spline is planar
    UserMessage = IIf(splineObj.IsPlanar, "is planar", "is not planar")
    MsgBox "The new Spline " & UserMessage
(defun c:Example_IsPlanar()
    ;; This example creates a Spline object in model space and
    ;; determines whether the Spline is planar
    ;; Define the Spline object
    (setq startTan (vlax-3d-point 0.5 0.5 0)
          endTan (vlax-3d-point 0.5 0.5 0)
          fitPoints (vlax-make-safearray vlax-vbDouble '(0 . 8)))
    (vlax-safearray-fill fitPoints '(0 0 0
				     5 5 0
				     10 0 0
    ;; Create new Spline object
    (setq splineObj (vla-AddSpline modelSpace fitPoints startTan endTan))
    (vla-ZoomAll acadObj)
    ;; Display whether or not new Spline is planar
    (setq UserMessage (if (= (vla-get-IsPlanar splineObj) :vlax-true) "is planar" "is not planar"))
    (alert (strcat "The new Spline " UserMessage))
GMT+8, 2026-10-17 05:46
