IsLayout 属性 (ActiveX)
2024-5-18 18:33| 发布者: admin| 查看: 1005| 评论: 0|原作者: admin|来自: AutoCAD
确定给定块是否为布局块。
object.IsLayout
类型:块
此属性应用于的对象。
只读:是的
类型:布尔
  • True:块是布局。
  • False:块不是布局。
酒店与酒店合作。如果两个属性都是 ,则该块是一个简单的块。如果属性为 ,则该块是外部引用。如果属性为 ,则该块包含与布局关联的所有几何图形。IsLayoutIsXRefFalseIsXRefTrueIsLayoutTrue
Sub Example_IsLayout()
    ' This example cycles through each Block object in a drawing
    ' and determines whether style of each Block by accessing the
    ' IsLayout and IsXRef properties.  A Block
    ' object is also added at runtime so the results are mixed and do not only
    ' come from the default Blocks.
    Dim circleObj As AcadCircle
    Dim centerPoint(0 To 2) As Double, InsertPoint(0 To 2) As Double
    Dim radius As Double
    Dim newBlock As AcadBlock, insertedBlock As AcadBlockReference
    Dim tempBlock As AcadBlock
    Dim msg As String
    ' Define the Circle object that will be inserted into the block
    centerPoint(0) = 0: centerPoint(1) = 0: centerPoint(2) = 0
    InsertPoint(0) = 1: InsertPoint(1) = 1: InsertPoint(2) = 0
    radius = 0.5
    ' Create a new block to hold the Circle object
    Set newBlock = ThisDrawing.Blocks.Add(centerPoint, "CBlock")
    ' Add the Circle object to the new block object
    Set circleObj = ThisDrawing.Blocks("CBlock").AddCircle(centerPoint, radius)
    ' Add the new block to model space
    Set insertedBlock = ThisDrawing.ModelSpace.InsertBlock(InsertPoint, "CBlock", 1, 1, 1, 0)
    msg = vbCrLf & vbCrLf
    For Each tempBlock In ThisDrawing.Blocks
        If Not (tempBlock.IsLayout) And Not (tempBlock.IsXRef) Then
            ' Block is simple
            msg = msg & tempBlock.name & ": Simple"
        ElseIf tempBlock.IsXRef Then
            ' Block is an external reference
            msg = msg & tempBlock.name & ": External Reference"
            If tempBlock.IsLayout Then
                ' Block also contains layout geometry
                msg = msg & tempBlock.name & " and Contains Layout Geometry"
            End If
        ElseIf tempBlock.IsLayout Then
            ' Block contains layout geometry
            msg = msg & tempBlock.name & ": Contains Layout Geometry"
        End If
        msg = msg & vbCrLf      ' Move to next line
    Next
    ' Display Block information for this drawing
    MsgBox "Blocks in this drawing have the following styles: " & msg
(defun c:Example_IsLayout()
    ;; This example cycles through each Block object in a drawing
    ;; and determines whether style of each Block by accessing the
    ;; IsLayout and IsXRef properties.  A Block
    ;; object is also added at runtime so the results are mixed and do not only
    ;; come from the default Blocks.
    ;; Define the Circle object that will be inserted into the block
    (setq centerPoint (vlax-3d-point 0 0 0)
          insertPoint (vlax-3d-point 1 1 0)
          radius 0.5)
    ;; Create a new block to hold the Circle object
    (setq newBlock (vla-Add (vla-get-Blocks doc) centerPoint "CBlock"))
    ;; Add the Circle object to the new block object
    (setq circleObj (vla-AddCircle (vla-Item (vla-get-Blocks doc) "CBlock") centerPoint radius))
    ;; Add the new block to model space
    (setq insertedBlock (vla-InsertBlock modelSpace InsertPoint "CBlock" 1 1 1 0))
    (vla-ZoomAll acadObj)
    (setq msg "")
    (vlax-for tempBlock (vla-get-Blocks doc)
        (cond
            ((and (= (vla-get-IsLayout tempBlock) :vlax-false)
                  (= (vla-get-IsXRef tempBlock) :vlax-false))
                ;; Block is simple
                (setq msg (strcat msg (vla-get-Name tempBlock) ": Simple"))
            ((= (vla-get-IsXRef tempBlock) :vlax-true)
                ;; Block is simple
                (setq msg (strcat msg (vla-get-Name tempBlock) ": External Reference"))
                (if (= (vla-get-IsLayout tempBlock) :vlax-true)
                    ;; Block also contains layout geometry
                    (setq msg (strcat msg (vla-get-Name tempBlock) " and Contains Layout Geometry"))
            ((= (vla-get-IsLayout tempBlock) :vlax-true)
                ;; Block is simple
                (setq msg (strcat msg (vla-get-Name tempBlock) ": Contains Layout Geometry"))
        (setq msg (strcat msg "\n"))
    ;; Display Block information for this drawing
    (alert (strcat "Blocks in this drawing have the following styles: " msg))
GMT+8, 2026-10-28 01:33
