ImageFrameHighlight 属性 (ActiveX)
2024-5-18 18:33| 发布者: admin| 查看: 750| 评论: 0|原作者: admin|来自: AutoCAD
控制选择期间光栅图像的显示。
object.ImageFrameHighlight
类型:首选项显示
此属性应用于的对象。
只读:不
类型:布尔
  • True:选择图像时显示光栅图像帧。
  • False:选择影像时显示光栅影像内容。
此属性的初始值为 。True
注意:此属性的此值存储在 IMAGEHLT 系统变量中。
Sub Example_ImageFrameHighlight()
    ' This example reads and modifies the preference value that controls
    ' the display of raster images during selection. When finished, this example
    ' resets the preference value back to its original value.
    Dim ACADPref As AcadPreferencesDisplay
    ' Get the display preferences object
    Set ACADPref = ThisDrawing.Application.preferences.DISPLAY
    originalValue = ACADPref.ImageFrameHighlight
    MsgBox "The ImageFrameHighlight preference is set to: " & originalValue
    ' Modify the ImageFrameHighlight preference by toggling the value
    ACADPref.ImageFrameHighlight = Not (originalValue)
    newValue = ACADPref.ImageFrameHighlight
    MsgBox "The ImageFrameHighlight preference has been set to: " & newValue
    '         this preference in effect
    ACADPref.ImageFrameHighlight = originalValue
    MsgBox "The ImageFrameHighlight preference was reset back to: " & originalValue
(defun c:Example_ImageFrameHighlight()
    ;; This example reads and modifies the preference value that controls
    ;; the display of raster images during selection. When finished, this example
    ;; resets the preference value back to its original value.
    (setq originalValue (vla-get-ImageFrameHighlight (vla-get-Display preferences)))
    (alert (strcat "The ImageFrameHighlight preference is set to: " (if (= originalValue :vlax-true) "True"  "False")))
    ;; Modify the ImageFrameHighlight preference by toggling the value
    (vla-put-ImageFrameHighlight (vla-get-Display preferences) (if (= originalValue :vlax-true) :vlax-false :vlax-true))
    (setq newValue (vla-get-ImageFrameHighlight (vla-get-Display preferences)))
    (alert (strcat "The ImageFrameHighlight preference has been set to: " (if (= newValue :vlax-true) "True"  "False")))
    ;;         this preference in effect
    (vla-put-ImageFrameHighlight (vla-get-Display preferences) originalValue)
    (alert (strcat "The ImageFrameHighlight preference was reset back to: " (if (= originalValue :vlax-true) "True"  "False")))
GMT+8, 2026-10-17 22:52
