HyperlinkDisplayCursor 属性 (ActiveX)
2024-5-18 18:33| 发布者: admin| 查看: 630| 评论: 0|原作者: admin|来自: AutoCAD
切换超链接光标和快捷菜单的显示。
object.HyperlinkDisplayCursor
类型:PreferencesUser
此属性应用于的对象。
只读:不
类型:布尔
  • True:显示超链接光标和快捷菜单。
  • False:不显示超链接光标和快捷菜单。
此属性的初始值为 。True
启用此属性后,每当光标位于包含超链接的对象上时,用户都会看到一个小位图(就在十字准线的下方和右侧)。禁用该属性后,将不会显示此位图。
Sub Example_HyperlinkDisplayCursor()
    ' This example reads and modifies the preference value that controls
    ' the display of the hyperlink cursor and shortcut menu.
    ' When finished, this example resets the preference value back to
    ' its original value.
    Dim ACADPref As AcadPreferencesUser
    ' Get the user preferences object
    Set ACADPref = ThisDrawing.Application.preferences.User
    originalValue = ACADPref.HyperlinkDisplayCursor
    MsgBox "The HyperlinkDisplayCursor preference is set to: " & originalValue
    ' Modify the HyperlinkDisplayCursor preference by toggling the value
    ACADPref.HyperlinkDisplayCursor = Not (ACADPref.HyperlinkDisplayCursor)
    newValue = ACADPref.HyperlinkDisplayCursor
    MsgBox "The HyperlinkDisplayCursor preference has been set to: " & newValue
    '         this preference in effect
    ACADPref.HyperlinkDisplayCursor = originalValue
    MsgBox "The HyperlinkDisplayCursor preference was reset back to: " & originalValue
(defun c:Example_HyperlinkDisplayCursor()
    ;; This example reads and modifies the preference value that controls
    ;; the display of the hyperlink cursor and shortcut menu.
    ;; When finished, this example resets the preference value back to
    ;; its original value.
    (setq originalValue (vla-get-HyperlinkDisplayCursor (vla-get-User preferences)))
    (alert (strcat "The HyperlinkDisplayCursor preference is set to: " (if (= originalValue :vlax-true) "True"  "False")))
    ;; Modify the HyperlinkDisplayCursor preference by toggling the value
    (vla-put-HyperlinkDisplayCursor (vla-get-User preferences) (if (= originalValue :vlax-true) :vlax-false :vlax-true))
    (setq newValue (vla-get-HyperlinkDisplayCursor (vla-get-User preferences)))
    (alert (strcat "The HyperlinkDisplayCursor preference has been set to: " (if (= newValue :vlax-true) "True"  "False")))
    ;;         this preference in effect
    (vla-put-HyperlinkDisplayCursor (vla-get-User preferences) originalValue)
    (alert (strcat "The HyperlinkDisplayCursor preference was reset back to: " (if (= originalValue :vlax-true) "True"  "False")))
GMT+8, 2026-11-30 11:03
