HatchStyle 属性 (ActiveX)
2024-5-18 18:33| 发布者: admin| 查看: 648| 评论: 0|原作者: admin|来自: AutoCAD
指定填充样式。
object.HatchStyle
类型:舱口
此属性应用于的对象。
只读:不
类型:枚举acHatchStyle
  • acHatchStyleNormal
  • acHatchStyleOuter
  • acHatchStyleIgnore
    指定标准样式或普通样式。此选项从最外层区域边界向内剖面线。如果 AutoCAD 遇到内部边界,则在遇到另一个边界之前会关闭剖面线。
  • acHatchStyleOuter
    仅填充最外层区域。此样式也会从区域边界向内剖面,但如果遇到内部边界,则会关闭剖面线,并且不会再次打开。
    忽略内部结构。此选项将剖面线穿过所有内部对象。
Sub Example_HatchStyle()
    ' This example creates an associative hatch in model space.
    ' The hatch style is then changed to demonstrate the different
    ' ways that inner loops are processed.
    Dim hatchObj As AcadHatch
    Dim patternName As String
    Dim PatternType As Long
    Dim bAssociativity As Boolean
    ' Define the hatch
    patternName = "ANSI31"
    PatternType = 0
    bAssociativity = True
    ' Create the associative Hatch object
    Set hatchObj = ThisDrawing.ModelSpace.AddHatch(PatternType, patternName, bAssociativity)
    ' Create the outer loop for the hatch.
    ' An arc and a line are used to create a closed loop.
    Dim outerLoop(0 To 1) As AcadEntity
    Dim center(0 To 2) As Double
    Dim radius As Double
    Dim startAngle As Double
    Dim endAngle As Double
    center(0) = 5: center(1) = 3: center(2) = 0
    radius = 3
    startAngle = 0
    endAngle = 3.141592
    Set outerLoop(0) = ThisDrawing.ModelSpace.AddArc(center, radius, startAngle, endAngle)
    Set outerLoop(1) = ThisDrawing.ModelSpace.AddLine(outerLoop(0).startPoint, outerLoop(0).endPoint)
    ' Append the outer loop to the hatch object
    hatchObj.AppendOuterLoop (outerLoop)
    ' Append the first circle as one inner loop
    Dim innerLoop1(0) As AcadEntity
    center(0) = 5: center(1) = 4.5: center(2) = 0
    radius = 1
    Set innerLoop1(0) = ThisDrawing.ModelSpace.AddCircle(center, radius)
    hatchObj.AppendInnerLoop (innerLoop1)
    ' Append the second circle as the other inner loop
    Dim innerLoop2(0) As AcadEntity
    radius = 0.5
    Set innerLoop2(0) = ThisDrawing.ModelSpace.AddCircle(center, radius)
    hatchObj.AppendInnerLoop (innerLoop2)
    ' Set the hatch style to normal
    hatchObj.hatchstyle = acHatchStyleNormal
    hatchObj.Evaluate
    ThisDrawing.Regen True
    MsgBox "The HatchStyle is set to " & Choose(hatchObj.hatchstyle + 1, "acHatchStyleNormal", "acHatchStyleOuter", "acHatchStyleIgnore"), , "HatchStyle Example"
    ' Set the hatch style to outer
    hatchObj.hatchstyle = acHatchStyleOuter
    hatchObj.Evaluate
    ' Set the hatch style to ignore
    hatchObj.hatchstyle = acHatchStyleIgnore
    hatchObj.Evaluate
(defun c:Example_HatchStyle()
    ;; This example creates an associative hatch in model space.
    ;; The hatch style is then changed to demonstrate the different
    ;; ways that inner loops are processed.
    ;; Define the hatch
    (setq patternName "ANSI31"
          patternType 0
          bAssociativity :vlax-true)
    ;; Create the associative Hatch object
    (setq hatchObj (vla-AddHatch modelSpace patternType patternName bAssociativity acHatchObject))
    ;; Create the outer loop for the hatch.
    ;; An arc and a line are used to create a closed loop.
    (setq center (vlax-3d-point 5 3 0)
          radius 3
          startAngle 0
          endAngle 3.141592)
    (setq arc (vla-AddArc modelSpace center radius startAngle endAngle))
    (setq line (vla-AddLine modelSpace (vla-get-StartPoint arc) (vla-get-EndPoint arc)))
    (setq outerLoop (vlax-make-safearray vlax-vbObject '(0 . 1)))
    (vlax-safearray-put-element outerLoop 0 arc)
    (vlax-safearray-put-element outerLoop 1 line)
    ;; Append the outer loop to the hatch object, and display the hatch
    (vla-AppendOuterLoop hatchObj outerLoop)
    ;; Append a circle as the inner loop for the hatch.
    (setq center (vlax-3d-point 5 4.5 0))
    (setq radius 1)
    (setq circle1 (vla-AddCircle modelSpace center radius))
    (setq innerLoop1 (vlax-make-safearray vlax-vbObject '(0 . 0)))
    (vlax-safearray-put-element innerLoop1 0 circle1)
    (vla-AppendInnerLoop hatchObj innerLoop1)
    ;; Append the second circle as the other inner loop
    (setq radius 0.5)
    (setq innerLoop2 (vlax-make-safearray vlax-vbObject '(0 . 0)))
    (setq circle2 (vla-AddCircle modelSpace center radius))
    (vlax-safearray-put-element innerLoop2 0 circle2)
    (vla-AppendInnerLoop hatchObj innerLoop2)
    (vla-ZoomAll acadObj)
    ;; Set the hatch style to normal
    (vla-put-hatchstyle hatchObj acHatchStyleNormal)
    (vla-Evaluate hatchObj)
    (vla-Regen doc :vlax-true)
    (alert (strcat "The HatchStyle is set to "
                   (cond
                     ((= (vla-get-hatchstyle hatchObj) 0) "acHatchStyleNormal")
                     ((= (vla-get-hatchstyle hatchObj) 1) "acHatchStyleOuter")
                     ((= (vla-get-hatchstyle hatchObj) 2) "acHatchStyleIgnore")
    ;; Set the hatch style to outer
    (vla-put-hatchstyle hatchObj acHatchStyleOuter)
                   (cond
    ;; Set the hatch style to ignore
    (vla-put-hatchstyle hatchObj acHatchStyleIgnore)
                   (cond
GMT+8, 2026-10-30 16:19
