HasExtensionDictionary 属性 (ActiveX)
2024-5-18 18:33| 发布者: admin| 查看: 816| 评论: 0|原作者: admin|来自: AutoCAD
确定对象是否具有与之关联的扩展字典。
object.HasExtensionDictionary
类型:所有绘图对象、 AttributeReference、 块、 字典、 DimStyle、 组、 图层、 布局、 线型、 材质、 MLeaderStyle、 PlotConfiguration、 RegisteredApplication、 SectionManager、 SectionSettings、 SortentsTable、 TableStyle、 TextStyle、UCS、视图、视口、XRecord
此属性应用于的对象。
只读:是的
类型:布尔
  • True:对象具有与之关联的扩展字典。
  • False:对象没有与之关联的扩展字典。
您可以为对象创建扩展字典,也可以使用该方法查询现有扩展字典。GetExtensionDictionary
Sub Example_HasExtensionDictionary()
    ' This example will iterate through each object in the current drawing and
    ' determine whether that object has an associated Extension Dictionary
    Dim DrawingObject As AcadObject
    Dim ExtensionDictionaryResults As String
    ' Make sure this drawing contains objects before continuing
    If ThisDrawing.ModelSpace.count = 0 Then
        MsgBox "There are no objects in the current drawing."
        Exit Sub
    End If
    For Each DrawingObject In ThisDrawing.ModelSpace
        ' Determine whether object contains Extension Dictionary
        Select Case DrawingObject.HasExtensionDictionary
            Case True
                ExtensionDictionaryResults = ExtensionDictionaryResults & _
                                             DrawingObject.ObjectName & _
                                             " has an associated Extension Dictionary" & vbCrLf
            Case False
                ExtensionDictionaryResults = ExtensionDictionaryResults _
                                             & DrawingObject.ObjectName & _
                                             " does not have an associated Extension Dictionary" & vbCrLf
        End Select
    Next
    MsgBox ExtensionDictionaryResults
(defun c:Example_HasExtensionDictionary()
    ;; This example will iterate through each object in the current drawing and
    ;; determine whether that object has an associated Extension Dictionary
    ;; Make sure this drawing contains objects before continuing
    (if (= (vla-get-Count modelSpace) 0)
        (alert "There are no objects in the current drawing.")
        (progn
            (setq ExtensionDictionaryResults "")
	           (vlax-for DrawingObject modelSpace
	               ;; Determine whether object contains Extension Dictionary
	               (cond
                    ((= (vla-get-HasExtensionDictionary DrawingObject) :vlax-true)
                        (setq ExtensionDictionaryResults (strcat ExtensionDictionaryResults
        (vla-get-ObjectName DrawingObject)
        " has an associated Extension Dictionary.\n")))
                    ((= (vla-get-HasExtensionDictionary DrawingObject) :vlax-false)
        " does not have an associated Extension Dictionary.\n")))
	    (alert ExtensionDictionaryResults)
GMT+8, 2026-10-28 08:16
