Groups 属性 (ActiveX)
获取文档的 Groups 集合。 支持的平台:仅限 Windows 言论没有其他评论。 例子VBA: Sub Example_Groups()
' This example finds the current Groups collection and
' adds a new group to that collection.
Dim groupColl As AcadGroups
Set groupColl = ThisDrawing.Groups
' Create a dimension style named "TEST" in current drawing
Dim testGroup As AcadGroup
Set testGroup = groupColl.Add("TEST")
MsgBox "A new group called " & testGroup.name & " has been added to the Groups collection.", vbInformation, "Groups Example"
可视化 LISP: (vl-load-com)
(defun c:Example_Groups()
;; This example finds the current Groups collection and
;; adds a new group to that collection.
(setq groupColl (vla-get-Groups doc))
;; Create a dimension style named "TEST" in current drawing
(setq testGroup (vla-Add groupColl "TEST"))
(alert (strcat "A new group called " (vla-get-Name testGroup) " has been added to the Groups collection."))
GMT+8, 2026-10-28 01:10
