GripSize 属性 (ActiveX)
2024-5-18 18:33| 发布者: admin| 查看: 820| 评论: 0|原作者: admin|来自: AutoCAD
指定夹点的大小。
object.GripSize
类型:首选项选择
此属性应用于的对象。
只读:不
类型:朗特
为显示夹点而绘制的框的大小,以像素为单位。此属性的实际范围是 1 到 20,但从 1 到 255 的任何值都是有效的。
此属性的初始值为 3。
注意:此属性的值存储在 GRIPSIZE 系统变量中。
Sub Example_GripSize()
    ' This example reads and modifies the preference value that controls
    ' the size of grips. When finished, this example resets the
    ' preference value back to its original value.
    Dim ACADPref As AcadPreferencesSelection
    ' Get the selection preferences object
    Set ACADPref = ThisDrawing.Application.preferences.Selection
    originalValue = ACADPref.GripSize
    MsgBox "The GripSize preference is set to: " & originalValue
    ' Modify the GripSize preference by setting it to 5
    ACADPref.GripSize = 5
    newValue = ACADPref.GripSize
    MsgBox "The GripSize preference has been set to: " & newValue
    '         this preference in effect
    ACADPref.GripSize = originalValue
    MsgBox "The GripSize preference was reset back to: " & originalValue
(defun c:Example_GripSize()
    ;; This example reads and modifies the preference value that controls
    ;; the size of grips. When finished, this example resets the
    ;; preference value back to its original value.
    ;; Get the selection preferences object
    (setq ACADPref (vla-get-Selection (vla-get-preferences acadObj)))
    (setq originalValue (vla-get-GripSize ACADPref))
    (alert (strcat "The GripSize preference is set to: " (itoa originalValue)))
    ;; Modify the GripSize preference by setting it to 7
    (vla-put-GripSize ACADPref 7)
    (setq newValue (vla-get-GripSize ACADPref))
    (alert (strcat "The GripSize preference has been set to: " (itoa newValue)))
    ;;         this preference in effect
    (vla-put-GripSize ACADPref originalValue)
    (alert (strcat "The GripSize preference was reset back to: " (itoa originalValue)))
GMT+8, 2026-10-17 20:59
