GraphicsWinLayoutBackgrndColor 属性 (ActiveX)
2024-5-18 18:33| 发布者: admin| 查看: 788| 评论: 0|原作者: admin|来自: AutoCAD
指定图纸空间布局的背景颜色。
object.GraphicsWinLayoutBackgrndColor
类型:首选项显示
此属性应用于的对象。
只读:不
类型:OLE_COLOR(常量)
  • vb黑色
  • vb红色
  • vb黄色
  • vb绿色
  • vb青色
  • vbBlue的
  • vb品红色
  • vb白色
此属性的初始值是介于 Windows 标准背景色和 Windows 标准活动按钮颜色之间的颜色。
图纸空间窗口由 AutoCAD 中的“布局”选项卡标识。模型空间窗口由“模型”选项卡标识。可以使用该属性更改模型空间窗口的背景颜色。GraphicsWinModelBackgrndColor
Sub Example_GraphicsWinLayoutBackgrndColor()
    ' GraphicsWinLayoutBackgrndColor. It then changes the value, and finally
    Dim currGraphicsWinLayoutBackgrndColor As OLE_COLOR
    Set preferences = ThisDrawing.Application.preferences
    ' Retrieve the current GraphicsWinLayoutBackgrndColor value
    currGraphicsWinLayoutBackgrndColor = preferences.DISPLAY.GraphicsWinLayoutBackgrndColor
    MsgBox "The current value for GraphicsWinLayoutBackgrndColor is " _
            & preferences.DISPLAY.GraphicsWinLayoutBackgrndColor, vbInformation, "GraphicsWinLayoutBackgrndColor Example"
    ' Change the value for GraphicsWinLayoutBackgrndColor
    preferences.DISPLAY.GraphicsWinLayoutBackgrndColor = 16
    MsgBox "The new value for GraphicsWinLayoutBackgrndColor is " _
    ' Reset GraphicsWinLayoutBackgrndColor to its original value
    preferences.DISPLAY.GraphicsWinLayoutBackgrndColor = currGraphicsWinLayoutBackgrndColor
    MsgBox "The GraphicsWinLayoutBackgrndColor value is reset to " _
(defun c:Example_GraphicsWinLayoutBackgrndColor()
    ;; GraphicsWinLayoutBackgrndColor. It then changes the value, and finally
    ;; Set PaperSpace/Layout current
    (vla-put-ActiveSpace doc acPaperSpace)
    ;; Retrieve the current GraphicsWinLayoutBackgrndColor value
    (setq currGraphicsWinLayoutBackgrndColor (vlax-variant-change-type (vla-get-GraphicsWinLayoutBackgrndColor (vla-get-Display preferences)) vlax-vbLong))
    (alert (strcat "The current value for GraphicsWinLayoutBackgrndColor is " (itoa (vlax-variant-value currGraphicsWinLayoutBackgrndColor))))
    ;; Change the value for GraphicsWinLayoutBackgrndColor
    (vla-put-GraphicsWinLayoutBackgrndColor ACADPref (vlax-make-variant 127 19))
    (setq newValue (vlax-variant-change-type (vla-get-GraphicsWinLayoutBackgrndColor ACADPref) vlax-vbLong))
    (alert (strcat "The new value for GraphicsWinLayoutBackgrndColor is " (itoa (vlax-variant-value newValue))))
    ;; Reset GraphicsWinLayoutBackgrndColor to its original value
    (vla-put-GraphicsWinLayoutBackgrndColor ACADPref currGraphicsWinLayoutBackgrndColor)
    (alert (strcat "The GraphicsWinLayoutBackgrndColor value is reset to " (itoa (vlax-variant-value currGraphicsWinLayoutBackgrndColor))))
GMT+8, 2026-11-30 11:02
