FullName 属性 (ActiveX)
2024-5-18 18:33| 发布者: admin| 查看: 676| 评论: 0|原作者: admin|来自: AutoCAD
获取应用程序或文档的名称,包括路径。
object.FullName
类型:应用程序,文档
此属性应用于的对象。
只读:是的
类型:字符串
应用程序或文档的名称和路径。
Sub Example_FullName()
    ' This example uses the FullName property to find
    ' the full name of the current drawing, and of
    ' the application.
    ' Find the full name of current drawing file including path.
    ' (If the drawing has not been saved, this name will be blank.)
    Dim docName As String
    docName = ThisDrawing.FullName
    MsgBox "The full name of the current drawing is " & docName, , "FullName Example"
    ' Find the full name of application
    Dim appName As String
    appName = ThisDrawing.Application.FullName
    MsgBox "The full name of the current application is " & appName, , "FullName Example"
(defun c:Example_FullName()
    ;; This example uses the FullName property to find
    ;; the full name of the current drawing, and of
    ;; the application.
    ;; Find the full name of current drawing file including path.
    ;; (If the drawing has not been saved, this name will be blank.)
    (setq docName (vla-get-FullName doc))
    (alert (strcat "The full name of the current drawing is " docName))
    ;; Find the full name of application
    (setq appName (vla-get-FullName acadObj))
    (alert (strcat "The full name of the current application is " appName))
GMT+8, 2026-11-25 15:27
