FullCRCValidation 属性 (ActiveX)
2024-5-18 18:33| 发布者: admin| 查看: 977| 评论: 0|原作者: admin|来自: AutoCAD
指定每次将对象读入图形时是否应执行循环冗余校验 (CRC)。
object.FullCRCValidation
类型:PreferencesOpenSave
此属性应用于的对象。
只读:不
类型:布尔
  • True:开启全时循环冗余校验。
  • False:关闭全时循环冗余检查。
此属性的初始值为 。False
如果图形已损坏,并且您怀疑存在硬件问题或AutoCAD错误,请设置为 。FullCRCValidationTrue
Sub Example_FullCRCValidation()
    ' FullCRCValidation. It then changes the value, and finally
    Dim currFullCRCValidation As Boolean
    Set preferences = ThisDrawing.Application.preferences
    ' Retrieve the current FullCRCValidation value
    currFullCRCValidation = preferences.OpenSave.FullCRCValidation
    MsgBox "The current value for FullCRCValidation is " & preferences.OpenSave.FullCRCValidation, vbInformation, "FullCRCValidation Example"
    ' Change the value for FullCRCValidation
    preferences.OpenSave.FullCRCValidation = Not (currFullCRCValidation)
    MsgBox "The new value for FullCRCValidation is " & preferences.OpenSave.FullCRCValidation, vbInformation, "FullCRCValidation Example"
    ' Reset FullCRCValidation to its original value
    preferences.OpenSave.FullCRCValidation = currFullCRCValidation
    MsgBox "The FullCRCValidation value is reset to " & preferences.OpenSave.FullCRCValidation, vbInformation, "FullCRCValidation Example"
(defun c:Example_FullCRCValidation()
    ;; FullCRCValidation. It then changes the value, and finally
    ;; Retrieve the current FullCRCValidation value
    (setq currFullCRCValidation (vla-get-FullCRCValidation (vla-get-OpenSave preferences)))
    (alert (strcat "The current value for FullCRCValidation is " (if (= currFullCRCValidation :vlax-true) "True" "False")))
    ;; Change the value for FullCRCValidation
    (setq newFullCRCValidation (if (= currFullCRCValidation :vlax-true) :vlax-false :vlax-true))
    (vla-put-FullCRCValidation (vla-get-OpenSave preferences) newFullCRCValidation)
    (alert (strcat "The new value for FullCRCValidation is " (if (= newFullCRCValidation :vlax-true) "True" "False")))
    ;; Reset FullCRCValidation to its original value
    (vla-put-FullCRCValidation (vla-get-OpenSave preferences) currFullCRCValidation)
    (alert (strcat "The FullCRCValidation value is reset to " (if (= currFullCRCValidation :vlax-true) "True" "False")))
GMT+8, 2026-11-29 10:57
