ExtLine2StartPoint 属性 (ActiveX)
2024-5-18 18:33| 发布者: admin| 查看: 652| 评论: 0|原作者: admin|来自: AutoCAD
指定第二条延伸线的起点。
object.ExtLine2StartPoint
类型:DimAngular
此属性应用于的对象。
只读:不
类型:变体(双打的三元素阵列)
表示第二条延伸线起点的 3D 坐标。
and 属性等于方法中的 and 参数。延伸线最初是从 和 位置绘制到尺寸线的交点。AutoCAD 将尺寸标注线绘制为延长线之间的圆弧。ExtLine1StartPointExtLine2StartPointFirstEndPointSecondEndPointAddDimAngularFirstEndPointSecondEndPoint
Sub Example_ExtLine2StartPoint()
    ' This example creates an angular dimension. It then changes
    ' the location of the ExtLine2StartPoint.
    Dim dimObj As AcadDimAngular
    Dim angVert(0 To 2) As Double
    Dim FirstPoint(0 To 2) As Double
    Dim SecondPoint(0 To 2) As Double
    Dim TextPoint(0 To 2) As Double
    ' Define the dimension
    angVert(0) = 0#: angVert(1) = 5#: angVert(2) = 0#
    FirstPoint(0) = 1#: FirstPoint(1) = 7#: FirstPoint(2) = 0#
    SecondPoint(0) = 1#: SecondPoint(1) = 3#: SecondPoint(2) = 0#
    TextPoint(0) = 3#: TextPoint(1) = 5#: TextPoint(2) = 0#
    ' Create the angular dimension in model space
    Set dimObj = ThisDrawing.ModelSpace.AddDimAngular(angVert, FirstPoint, SecondPoint, TextPoint)
    ZoomAll
    MsgBox "The current value of ExtLine2StartPoint is " & dimObj.ExtLine2StartPoint(0) & ", " & dimObj.ExtLine2StartPoint(1) & ", " & dimObj.ExtLine2StartPoint(2), vbInformation, "ExtLine2StartPoint Example"
    ' Change the start point of the second extension line
    FirstPoint(0) = 1: FirstPoint(1) = 4: FirstPoint(2) = 0
    dimObj.ExtLine2StartPoint = FirstPoint
    dimObj.Update
    ' Return the start point of the second extension line
    ' Note that the return value is a Variant
    Dim retPnt As Variant
    retPnt = dimObj.ExtLine2StartPoint
    MsgBox "The new value of ExtLine2StartPoint is " & dimObj.ExtLine2StartPoint(0) & ", " & dimObj.ExtLine2StartPoint(1) & ", " & dimObj.ExtLine2StartPoint(2), vbInformation, "ExtLine2StartPoint Example"
(defun c:Example_ExtLine2StartPoint()
    ;; This example creates an angular dimension. It then changes
    ;; the location of the ExtLine2StartPoint.
    ;; Define the dimension
    (setq AngleVertex (vlax-3d-point 0 5 0)
          FirstPoint (vlax-3d-point 1 7 0)
          SecondPoint (vlax-3d-point 1 3 0)
          TextPoint (vlax-3d-point 3 5 0))
    ;; Create the angular dimension in model space
    (setq dimObj (vla-AddDimAngular modelSpace AngleVertex FirstPoint SecondPoint TextPoint))
    (vla-ZoomAll acadObj)
    (setq extLineStartPoint (vlax-safearray->list (vlax-variant-value (vla-get-ExtLine2StartPoint dimObj))))
    (alert (strcat "The current value of ExtLine2StartPoint is " (rtos (nth 0 extLineStartPoint) 2) ", "
		                                                 (rtos (nth 1 extLineStartPoint) 2) ", "
		                                                 (rtos (nth 2 extLineStartPoint) 2)))
    ;; Change the start point of the second extension line
    (setq FirstPoint (vlax-3d-point 1 4 0))
    (vla-put-ExtLine2StartPoint dimObj FirstPoint)
    (vla-Update dimObj)
    ;; Return the start point of the second extension line
    ;; Note that the return value is a Variant
    (setq retPnt (vlax-safearray->list (vlax-variant-value (vla-get-ExtLine2StartPoint dimObj))))
    (alert (strcat "The new value of ExtLine2StartPoint is " (rtos (nth 0 retPnt) 2) ", "
		                                             (rtos (nth 1 retPnt) 2) ", "
		                                             (rtos (nth 2 retPnt) 2)))
GMT+8, 2026-10-27 08:58
