ExtensionLineExtend 属性 (ActiveX)
指定延伸线延伸到尺寸线之外的距离。 支持的平台:仅限 Windows 签名VBA: object.ExtensionLineExtend
属性值只读:不 类型:双 一个正实数,指定将延伸线延伸到尺寸线之外的距离。 言论此属性的初始值为 0.1800。 注意:此属性将覆盖给定维度的 DIMEXE 系统变量的值。
例子VBA: Sub Example_ExtensionLineExtend()
' This example creates a Dim3PointAngular object in model space
' and changes the length of the extension line to extend 1.5 units past
' the dimension using the ExtensionLineExtend property
Dim DimPointAngularObj As AcadDim3PointAngular
Dim AngleVertex(0 To 2) As Double
Dim FirstPoint(0 To 2) As Double, SecondPoint(0 To 2) As Double
Dim TextPoint(0 To 2) As Double
' Define the new Dim3PointAngular object
AngleVertex(0) = 0: AngleVertex(1) = 0: AngleVertex(2) = 0
FirstPoint(0) = 2: FirstPoint(1) = 2: FirstPoint(2) = 0
SecondPoint(0) = 1: SecondPoint(1) = 4: SecondPoint(2) = 0
TextPoint(0) = 6: TextPoint(1) = 6: TextPoint(2) = 0
' Create the new Dim3PointAngular object in model space
Set DimPointAngularObj = ThisDrawing.ModelSpace.AddDim3PointAngular(AngleVertex, FirstPoint, SecondPoint, TextPoint)
' Read and display current extension line extend length
MsgBox "The extension line currently extends " & DimPointAngularObj.ExtensionLineExtend & " units past the dimension"
' Change the extension line extend length to extend 1.5
' units past the dimension
DimPointAngularObj.ExtensionLineExtend = 1.5
MsgBox "The extension line now extends " & DimPointAngularObj.ExtensionLineExtend & " units past the dimension"
可视化 LISP: (vl-load-com)
(defun c:Example_ExtensionLineExtend()
;; This example creates a Dim3PointAngular object in model space
;; and changes the length of the extension line to extend 1.5 units past
;; the dimension using the ExtensionLineExtend property
;; Define the new Dim3PointAngular object
(setq AngleVertex (vlax-3d-point 0 0 0)
FirstPoint (vlax-3d-point 2 2 0)
SecondPoint (vlax-3d-point 1 4 0)
TextPoint (vlax-3d-point 6 6 0))
;; Create the new Dim3PointAngular object in model space
(setq DimPointAngularObj (vla-AddDim3PointAngular modelSpace AngleVertex FirstPoint SecondPoint TextPoint))
(vla-ZoomAll acadObj)
;; Read and display current extension line extend length
(alert (strcat "The extension line currently extends " (rtos (vla-get-ExtensionLineExtend DimPointAngularObj) 2) " units past the dimension"))
;; Change the extension line extend length to extend 1.5
;; units past the dimension
(vla-put-ExtensionLineExtend DimPointAngularObj 1.5)
(alert (strcat "The extension line now extends " (rtos (vla-get-ExtensionLineExtend DimPointAngularObj) 2) " units past the dimension"))
GMT+8, 2026-10-28 17:18
