DrawingDirection 属性 (ActiveX)
2024-5-18 18:33| 发布者: admin| 查看: 954| 评论: 0|原作者: admin|来自: AutoCAD
指定读取多行文本段落的方向。
object.DrawingDirection
类型:GeoPositionMarker、MText
此属性应用于的对象。
只读:不
类型:枚举acDrawingDirection
  • acLeftToRight
  • acTopToBottom
  • acRightToLeft(保留以备将来使用)
  • acBottomToTop(保留以备将来使用)
  • acByStyle(保留以备将来使用)
对于英语或西班牙语等语言,文本从左到右水平阅读。对于中文或日语等语言,有时文本是垂直阅读的,从上到下。AutoCAD将根据此特性设置绘制文本。
从左到右
从上到下
设置 、 和 保留供将来使用,不能在此版本中使用。acRightToLeftacBottomToTopacByStyle
Sub Example_DrawingDirection()
    ' This example changes the drawing direction for an MText object
    ' in model space.
    Dim MTextObj As AcadMText
    Dim corner1(0 To 2) As Double
    Dim width As Double
    Dim text As String
    ' Define the MText object
    corner1(0) = 0#: corner1(1) = 6#: corner1(2) = 0#
    width = 7
    text = "This is a text String."
    ' Create the MText object in model space
    Set MTextObj = ThisDrawing.ModelSpace.AddMText(corner1, width, text)
    ZoomAll
    'Change the drawing direction of the MText object
    MTextObj.DrawingDirection = acLeftToRight
    ZoomAll
    MsgBox "The DrawingDirection of the text is left to right.", vbInformation, "DrawingDirection Example"
    MTextObj.DrawingDirection = acTopToBottom
    ZoomAll
    MsgBox "The DrawingDirection of the text is top to bottom.", vbInformation, "DrawingDirection Example"
    ' Return the drawing direction
    Dim retDirection As Integer
    retDirection = MTextObj.DrawingDirection
(defun c:Example_DrawingDirection()
    ;; This example changes the drawing direction for an MText object
    ;; in model space.
    ;; Define the MText object
    (setq corner1 (vlax-3d-point 0 6 0)
          width 7
          text "This is a text String.")
    ;; Create the MText object in model space
    (setq MTextObj (vla-AddMText modelSpace corner1 width text))
    (vla-ZoomAll acadObj)
    ;; Change the drawing direction of the MText object
    (vla-put-DrawingDirection MTextObj acLeftToRight)
    (alert "The DrawingDirection of the text is left to right.")
    (vla-put-DrawingDirection MTextObj acTopToBottom)
    (alert "The DrawingDirection of the text is top to bottom.")
    ;; Return the drawing direction
    (setq retDirection (vla-get-DrawingDirection MTextObj))
    (alert (strcat "The current value of DrawingDirection: " (itoa retDirection)))
GMT+8, 2026-10-29 00:06
