DisplaySilhouette 属性 (ActiveX)
2024-5-18 18:33| 发布者: admin| 查看: 669| 评论: 0|原作者: admin|来自: AutoCAD
控制实体对象的轮廓曲线是否在线框模式下显示。
object.DisplaySilhouette
类型:DatabasePreferences
此属性应用于的对象。
只读:不
类型:布尔
  • True:仅显示实体对象的轮廓线。
  • False:显示实体对象的等值线。
此属性的初始值为 。False
注意:此属性的值存储在 DISPSILH 系统变量中。
Sub Example_DisplaySilhouette()
    ' DisplaySilhouette. It then changes the value, and finally
    Dim currDisplaySilhouette As Boolean
    ' Retrieve the current DisplaySilhouette value
    currDisplaySilhouette = ThisDrawing.Preferences.DisplaySilhouette
    MsgBox "The current value for DisplaySilhouette is " & preferences.DisplaySilhouette, vbInformation, "DisplaySilhouette Example"
    ' Change the value for DisplaySilhouette
    ThisDrawing.Preferences.DisplaySilhouette = Not (currDisplaySilhouette)
    MsgBox "The new value for DisplaySilhouette is " & preferences.DisplaySilhouette, vbInformation, "DisplaySilhouette Example"
    ' Reset DisplaySilhouette to its original value
    ThisDrawing.Preferences.DisplaySilhouette = currDisplaySilhouette
    MsgBox "The DisplaySilhouette value is reset to " & preferences.DisplaySilhouette, vbInformation, "DisplaySilhouette Example"
(defun c:Example_DisplaySilhouette()
    ;; DisplaySilhouette. It then changes the value, and finally
    (setq preferences (vla-get-Preferences doc))
    ;; Retrieve the current DisplaySilhouette value
    (setq currDisplaySilhouette (vla-get-DisplaySilhouette preferences))
    (alert (strcat "The current value for DisplaySilhouette is " (if (= currDisplaySilhouette :vlax-true) "True" "False")))
    ;; Change the value for DisplaySilhouette
    (setq newValue (if (= currDisplaySilhouette :vlax-true) :vlax-false :vlax-true))
    (vla-put-DisplaySilhouette preferences newValue)
    (alert (strcat "The new value for DisplaySilhouette is " (if (= newValue :vlax-true) "True" "False")))
    ;; Reset DisplaySilhouette to its original value
    (vla-put-DisplaySilhouette preferences currDisplaySilhouette)
    (alert (strcat "The DisplaySilhouette value is reset to " (if (= currDisplaySilhouette :vlax-true) "True" "False")))
GMT+8, 2026-10-28 09:02
