DisplayScrollBars 属性 (ActiveX)
指定是否在绘图窗口的底部和右侧显示滚动条。 支持的平台:仅限 Windows 属性值只读:不 类型:布尔
言论此属性的初始值为 。False 例子VBA: Sub Example_DisplayScrollBars()
' DisplayScrollBars. It then changes the value, and finally
Dim currDisplayScrollBars As Boolean
Set preferences = ThisDrawing.Application.Preferences
' Retrieve the current DisplayScrollBars value
currDisplayScrollBars = preferences.Display.DisplayScrollBars
MsgBox "The current value for DisplayScrollBars is " & preferences.DISPLAY.DisplayScrollBars, vbInformation, "DisplayScrollBars Example"
' Change the value for DisplayScrollBars
preferences.DISPLAY.DisplayScrollBars = Not (currDisplayScrollBars)
MsgBox "The new value for DisplayScrollBars is " & preferences.DISPLAY.DisplayScrollBars, vbInformation, "DisplayScrollBars Example"
' Reset DisplayScrollBars to its original value
preferences.DISPLAY.DisplayScrollBars = currDisplayScrollBars
MsgBox "The DisplayScrollBars value is reset to " & preferences.DISPLAY.DisplayScrollBars, vbInformation, "DisplayScrollBars Example"
可视化 LISP: (vl-load-com)
(defun c:Example_DisplayScrollBars()
;; DisplayScrollBars. It then changes the value, and finally
;; Get the Display preferences object
(setq ACADPref (vla-get-Display preferences))
;; Retrieve the current DisplayScrollBars value
(setq currDisplayScrollBars (vla-get-DisplayScrollBars ACADPref))
(alert (strcat "The current value for DisplayScrollBars is " (if (= currDisplayScrollBars :vlax-true) "True" "False")))
;; Change the value for DisplayScrollBars
(setq newValue (if (= currDisplayScrollBars :vlax-true) :vlax-false :vlax-true))
(vla-put-DisplayScrollBars ACADPref newValue)
(alert (strcat "The new value for DisplayScrollBars is " (if (= newValue :vlax-true) "True" "False")))
;; Reset DisplayScrollBars to its original value
(vla-put-DisplayScrollBars ACADPref currDisplayScrollBars)
(alert (strcat "The DisplayScrollBars value is reset to " (if (= currDisplayScrollBars :vlax-true) "True" "False")))
GMT+8, 2026-10-17 05:10
