DisplayOLEScale 属性 (ActiveX)
2024-5-18 18:33| 发布者: admin| 查看: 799| 评论: 0|原作者: admin|来自: AutoCAD
确定将 OLE 对象插入到图形中时是否显示 OLE 缩放对话框。
object.DisplayOLEScale
类型:PreferencesSystem
此属性应用于的对象。
只读:不
类型:布尔
  • True:将 OLE 对象插入到图形中时显示 OLE 缩放对话框。
  • False:将 OLE 对象插入到图形中时,不显示 OLE 缩放对话框。
此属性的初始值为 。True
Sub Example_DisplayOLEScale()
    ' This example reads and modifies the preference value that controls
    ' whether the OLE scaling dialog is displayed when OLE objects are
    ' inserted into a drawing.
    ' When finished, this example resets the preference value back to
    ' its original value.
    Dim ACADPref As AcadPreferencesSystem
    ' Get the system preferences object
    Set ACADPref = ThisDrawing.Application.Preferences.System
    originalValue = ACADPref.DisplayOLEScale
    MsgBox "The DisplayOLEScale preference is set to: " & originalValue
    ' Modify the DisplayOLEScale preference by toggling the value
    ACADPref.DisplayOLEScale = Not (ACADPref.DisplayOLEScale)
    newValue = ACADPref.DisplayOLEScale
    MsgBox "The DisplayOLEScale preference has been set to: " & newValue
    '         this preference in effect
    ACADPref.DisplayOLEScale = originalValue
    MsgBox "The DisplayOLEScale preference was reset back to: " & originalValue
(defun c:Example_DisplayOLEScale()
    ;; This example reads and modifies the preference value that controls
    ;; whether the OLE scaling dialog is displayed when OLE objects are
    ;; inserted into a drawing.
    ;; When finished, this example resets the preference value back to
    ;; its original value.
    ;; Get the system preferences object
    (setq ACADPref (vla-get-System preferences))
    (setq originalValue (vla-get-DisplayOLEScale ACADPref))
    (alert (strcat "The DisplayOLEScale preference is set to: " (if (= originalValue :vlax-true) "True" "False")))
    ;; Modify the DisplayOLEScale preference by toggling the value
    (vla-put-DisplayOLEScale ACADPref (if (= originalValue :vlax-true) :vlax-false :vlax-true))
    (setq newValue (vla-get-DisplayOLEScale ACADPref))
    (alert (strcat "The DisplayOLEScale preference has been set to: " (if (= newValue :vlax-true) "True" "False")))
    ;;         this preference in effect
    (vla-put-DisplayOLEScale ACADPref originalValue)
    (alert (strcat "The DisplayOLEScale preference was reset back to: " (if (= originalValue :vlax-true) "True" "False")))
GMT+8, 2026-12-1 04:24
