DimStyles 属性 (ActiveX)
2024-5-18 18:33| 发布者: admin| 查看: 897| 评论: 0|原作者: admin|来自: AutoCAD
获取文档的 DimStyles 集合。
object.DimStyles
类型:数据库、文档
此属性应用于的对象。
只读:是的
类型:DimStyles
文档的集合。DimStyles
Sub Example_DimStyles()
    ' This example adds a new dimension style.
    Dim dimStyle As AcadDimStyle
    Set dimStyle = ThisDrawing.DimStyles.Add("TEST")
    MsgBox "A new dimension style called " & dimStyle.name & " has been added to the Dimstyles collection.", vbInformation, "Dimstyles Example"
(defun c:Example_DimStyles()
    ;; This example adds a new dimension style.
    (setq dimStyle (vla-Add (vla-get-DimStyles doc) "TEST"))
    (alert (strcat "A new dimension style called " (vla-get-Name dimStyle) " has been added to the Dimstyles collection."))
GMT+8, 2026-10-17 22:59
