Dictionaries 属性 (ActiveX)
2024-5-18 18:33| 发布者: admin| 查看: 623| 评论: 0|原作者: admin|来自: AutoCAD
获取文档的 Dictionaries 集合。
object.Dictionaries
类型:数据库、文档
此属性应用于的对象。
只读:是的
类型: 字典
文档的集合。Dictionaries
Sub Example_Dictionaries()
    ' This example finds the current dictionary collection and
    ' adds a new dictionary to that collection.
    Dim dict As AcadDictionary
    Set dict = ThisDrawing.Dictionaries.Add("TEST")
    MsgBox "A new dictionary called " & dict.name & " has been added to the dictionaries collection.", vbInformation, "Dictionaries Example"
(defun c:Example_Dictionaries()
    ;; This example finds the current dictionary collection and
    ;; adds a new dictionary to that collection.
    (setq dict (vla-Add (vla-get-Dictionaries doc) "TEST"))
    (alert (strcat "A new dictionary called " (vla-get-Name dict) " has been added to the dictionaries collection."))
GMT+8, 2026-10-29 18:39
