Delta 属性 (ActiveX)
2024-5-18 18:33| 发布者: admin| 查看: 926| 评论: 0|原作者: admin|来自: AutoCAD
Delta 属性 (ActiveX)
获取线的增量。
object.Delta
类型:线
此属性应用于的对象。
只读:是的
类型:变体(双打的三元素阵列)
表示线的 deltaX、deltaY 和 deltaZ 值的三元素数组。
Sub Example_Delta()
    ' This example adds a line in model space and returns the delta of the new line
    Dim lineObj As AcadLine
    Dim lineDelta As Variant
    Dim startPoint(0 To 2) As Double, endPoint(0 To 2) As Double
    ' Define the start and end points for the line
    startPoint(0) = 1: startPoint(1) = 1: startPoint(2) = 0
    endPoint(0) = 5: endPoint(1) = 5: endPoint(2) = 0
    ' Create the line in model space
    Set lineObj = ThisDrawing.modelSpace.AddLine(startPoint, endPoint)
    ' Display the delta of the new line
    lineDelta = lineObj.Delta
    MsgBox "The delta of the new Line is: " & vbCrLf & _
           "DeltaX: " & lineDelta(0) & vbCrLf & _
           "DeltaY: " & lineDelta(1) & vbCrLf & _
           "DeltaZ: " & lineDelta(2)
(defun c:Example_Delta()
    ;; This example adds a line in model space and returns the delta of the new line
    ;; Define the start and end points for the line
    (setq startPoint (vlax-3d-point 1 1 0)
          endPoint (vlax-3d-point 5 5 0))
    ;; Create the line in model space
    (vla-ZoomAll acadObj)
    ;; Display the delta of the new line
    (setq lineDelta (vlax-safearray->list (vlax-variant-value (vla-get-Delta lineObj))))
    (alert (strcat "The delta of the new Line is: "
                   "\nDeltaX: " (rtos (nth 0 lineDelta) 2)
                   "\nDeltaY: " (rtos (nth 1 lineDelta) 2)
                   "\nDeltaZ: " (rtos (nth 2 lineDelta) 2)
GMT+8, 2026-11-17 07:50
