DefaultPlotStyleTable 属性 (ActiveX)
指定要附着到新图形的缺省打印样式表。 支持的平台:仅限 Windows 属性值只读:不 类型:字符串 打印样式表的扩展名为 .ctb 或 .stb,包含并定义打印样式。 言论如果使用的是与颜色相关的打印样式,则此选项可以设置为在搜索路径中找到的任何与颜色相关的打印样式表以及值“None”。如果使用命名的打印样式,则此选项可以设置为任何命名的打印样式表。 若要设置与颜色相关的打印样式,请使用该属性。PlotPolicy 例子VBA: Sub Example_DefaultPlotStyleTable()
' This example reads and modifies the preference value that
' specifies the default plot style table to attach to new drawings.
' Note: You may want to change the path of the new plot style table below.
Dim ACADPref As AcadPreferencesOutput
Dim CurrentFile As String
Const NewFile = "c:\monochrome.ctb"
' Get the drafting preferences object
Set ACADPref = ThisDrawing.Application.preferences.Output
' Read and display the current plot style table path
CurrentFile = ACADPref.DefaultPlotStyleTable
If CurrentFile = "" Then
MsgBox "There is no current plot style table being used", vbInformation
Else
MsgBox "The current plot style table is: " & CurrentFile
End If
' Use a new plot style table
ACADPref.DefaultPlotStyleTable = NewFile
' Read and display the new plot style table path
MsgBox "The new plot style table is: " & CurrentFile, vbInformation
可视化 LISP: (vl-load-com)
(defun c:Example_DefaultPlotStyleTable()
;; This example reads and modifies the preference value that
;; specifies the default plot style table to attach to new drawings.
;; Note: You may want to change the path of the new plot style table below.
(setq NewFile (strcat (vla-get-PrinterStyleSheetPath (vla-get-Files preferences)) "\\monochrome.ctb"))
;; Get the drafting preferences object
(setq ACADPref (vla-get-Output preferences))
;; Read and display the current plot style table path
(setq CurrentFile (vla-get-DefaultPlotStyleTable ACADPref))
(if (= CurrentFile "")
(alert "There is no current plot style table being used.")
(alert (strcat "The current plot style table is: " CurrentFile))
;; Use a new plot style table
(vla-put-DefaultPlotStyleTable ACADPref NewFile)
;; Read and display the new plot style table path
(alert (strcat "The new plot style table is: " (vla-get-DefaultPlotStyleTable ACADPref)))
(vla-put-DefaultPlotStyleTable ACADPref CurrentFile)
GMT+8, 2026-11-25 15:29
