DefaultPlotStyleForLayer 属性 (ActiveX)
2024-5-18 18:33| 发布者: admin| 查看: 837| 评论: 0|原作者: admin|来自: AutoCAD
指定新图形或使用早期版本的 AutoCAD 创建的图形的图纸的默认打印样式,这些图形从未以 AutoCAD 2000 或更高版本格式保存。
object.DefaultPlotStyleForLayer
类型:首选项输出
此属性应用于的对象。
只读:不
类型:字符串
您可以输入默认值“正常”,并输入在当前加载的打印样式表中定义的任何打印样式。
此属性的初始值为“Normal”。
仅当设置为 时,此属性才可用。PlotPolicyacPolicyNamed
使用该属性查找当前打印样式。DefaultPlotStyleTable
注意:此属性的值存储在 DEFLPLSTYLE 系统变量中。
Sub Example_DefaultPlotStyleForLayer()
    ' This example reads and modifies the preference value that controls
    ' the default plot style assigned to layers.
    ' When finished, this example resets the preference value back to
    ' its original value.
    Dim ACADPref As AcadPreferencesOutput
    Dim originalPolicyValue As Variant, originalValue As Variant, _
        originalPlotStyleTableValue As Variant, newValue As Variant
    ' Get the output preferences object
    Set ACADPref = ThisDrawing.Application.preferences.Output
    ' Set the default plot style to named plot styles
    originalPolicyValue = ACADPref.PlotPolicy
    ACADPref.PlotPolicy = acPolicyNamed
    originalValue = ACADPref.DefaultPlotStyleForLayer
    MsgBox "The DefaultPlotStyleForLayer preference is: " & originalValue
    originalPlotStyleTableValue = ACADPref.DefaultPlotStyleTable
    ACADPref.DefaultPlotStyleTable = "acad.stb"
    ' Toggle and display the DefaultPlotStyleForLayer preference
    If ACADPref.DefaultPlotStyleForLayer = "Style 1" Then
        ACADPref.DefaultPlotStyleForLayer = "Normal"
    Else
    End If
    newValue = ACADPref.DefaultPlotStyleForLayer
    MsgBox "The DefaultPlotStyleForLayer preference has been set to: " & newValue
    '         this preference in effect
    ACADPref.DefaultPlotStyleForLayer = originalValue
    MsgBox "The DefaultPlotStyleForLayer preference was reset back to: " & originalValue
    ' Restore the original plot style
    ACADPref.PlotPolicy = originalPolicyValue
    ACADPref.DefaultPlotStyleTable = originalPlotStyleTableValue
(defun c:Example_DefaultPlotStyleForLayer()
    ;; This example reads and modifies the preference value that controls
    ;; the default plot style assigned to layers.
    ;; When finished, this example resets the preference value back to
    ;; its original value.
    ;; Get the output preferences object
    (setq ACADPref (vla-get-Output preferences))
    ;; Set the default plot style to named plot styles
    (setq originalPolicyValue (vla-get-PlotPolicy ACADPref))
    (vla-put-PlotPolicy ACADPref acPolicyNamed)
    (setq originalPlotStyleTableValue (vla-get-DefaultPlotStyleTable ACADPref))
    (vla-put-DefaultPlotStyleTable ACADPref "acad.stb")
    (setq originalValue (vla-get-DefaultPlotStyleForLayer ACADPref))
    (alert (strcat "The DefaultPlotStyleForLayer preference is: " originalValue))
    ;; Toggle and display the DefaultPlotStyleForLayer preference
    (if (= (vla-get-DefaultPlotStyleForLayer ACADPref) "Style 1")
        (vla-put-DefaultPlotStyleForLayer ACADPref "Normal")
        (vla-put-DefaultPlotStyleForLayer ACADPref "Style 1")
    (setq newValue (vla-get-DefaultPlotStyleForLayer ACADPref))
    (alert (strcat "The DefaultPlotStyleForLayer preference has been set to: " newValue))
    ;;         this preference in effect
    (vla-put-DefaultPlotStyleForLayer ACADPref originalValue)
    (alert (strcat "The DefaultPlotStyleForLayer preference was reset back to: " originalValue))
    ;; Restore the original plot style
    (vla-put-PlotPolicy ACADPref originalPolicyValue)
    (vla-put-DefaultPlotStyleTable ACADPref originalPlotStyleTableValue)
GMT+8, 2026-11-29 10:48
