Count 属性 (ActiveX)
2024-5-18 18:33| 发布者: admin| 查看: 720| 评论: 0|原作者: admin|来自: AutoCAD
Count 属性 (ActiveX)
获取对象中的项数。
object.Count
类型:所有集合、块、字典、组、材料、SectionManager、SelectionSet
此属性应用于的对象。
只读:是的
类型:整数
对象中的项数。
发行信息
释放:AutoCAD 2000 到 AutoCAD 2017
Sub Example_Count()
    ' Use count to retrieve the number of objects in a collection
    ' You might use this value in a loop structure to iterate through the collection
    MsgBox "There are " & ThisDrawing.Layers.Count & " layer(s) in the drawing."
    MsgBox "There are " & ThisDrawing.ModelSpace.Count & " object(s) in ModelSpace."
    Dim objCount As Integer
    Dim I As Integer
    objCount = ThisDrawing.ModelSpace.Count
    Dim mspaceObj As AcadObject
    For I = 0 To objCount - 1
        Set mspaceObj = ThisDrawing.modelSpace.Item(I)
        MsgBox "The objects in ModelSpace include: " & mspaceObj.ObjectName, vbInformation, "Count Example"
    Next
(defun c:Example_Count()
    ;; Use count to retrieve the number of objects in a collection
    ;; You might use this value in a loop structure to iterate through the collection
    (alert (strcat "There are " (itoa (vla-get-Count (vla-get-Layers doc))) " layer(s) in the drawing."))
    (alert (strcat "There are " (itoa (vla-get-Count (vla-get-ModelSpace doc))) " object(s) in ModelSpace."))
    (setq I 0
	  objCount (vla-get-Count (vla-get-ModelSpace doc)))
    (while (>= (- objCount 1) I)
        (setq mspaceObj (vla-Item (vla-get-ModelSpace doc) I)
	      I (1+ I))
        (alert (strcat "The objects in ModelSpace include: " (vla-get-ObjectName mspaceObj)))
GMT+8, 2026-10-28 09:04
