Constant 属性 (ActiveX)
指定属性或属性引用是否为常量。 支持的平台:仅限 Windows 属性值只读:不,对象;是的,对象AttributeAttributeReference 类型:布尔
言论常量属性是在每次出现时都保持相同值的属性。AutoCAD 不会提示输入常量属性值。属性只能作为四种可选模式之一存在:常量、预设、不可见或验证。 注意:AFLAGS 系统变量存储当前模式设置。可以使用该属性查询当前模式。Mode
例子VBA: Sub Example_Constant()
' This example creates an attribute definition in model space.
' It then queries the attribute to see if it is a constant attribute.
Dim attributeObj As AcadAttribute
Dim height As Double
Dim mode As Long
Dim prompt As String
Dim tag As String
Dim value As String
' Define the attribute definition
height = 1#
mode = acAttributeModeVerify
prompt = "New Prompt"
insertionPoint(0) = 5#: insertionPoint(1) = 5#: insertionPoint(2) = 0
tag = "New_Tag"
value = "New Value"
' Create the attribute definition object in model space
Set attributeObj = ThisDrawing.ModelSpace.AddAttribute(height, mode, prompt, insertionPoint, tag, value)
ZoomAll
' Query the attribute
GoSub QUERYSTATUS
' Change the attribute
attributeObj.constant = Not attributeObj.constant
GoSub QUERYSTATUS
Exit Sub
QUERYSTATUS:
If attributeObj.constant Then
MsgBox "The attribute is a constant attribute."
Else
MsgBox "The attribute is not a constant attribute."
End If
Return
可视化 LISP: (vl-load-com)
(defun c:Example_Constant()
;; This example creates an attribute definition in model space.
;; It then queries the attribute to see if it is a constant attribute.
;; Define the attribute definition
(setq insertionPoint (vlax-3d-point 5 5 0)
attHeight 1
attMode acAttributeModeVerify
attPrompt "New Prompt"
attTag "New_Tag"
attValue "New Value")
;; Create the attribute definition object in model space
(setq attributeObj (vla-AddAttribute modelSpace attHeight attMode attPrompt insertionPoint attTag attValue))
(vla-ZoomAll acadObj)
;; Query the attribute
(if (= (vla-get-Constant attributeObj) :vlax-true)
(alert "The attribute is a constant attribute.")
(alert "The attribute is not a constant attribute.")
;; Change the attribute
(vla-put-Constant attributeObj (if (= (vla-get-Constant attributeObj) :vlax-true) :vlax-false :vlax-true))
GMT+8, 2026-10-27 10:47
