ColorBookPath 属性 (ActiveX)
设置颜色书路径。 支持的平台:仅限 Windows 属性值只读:不 类型:字符串 颜色书路径。 言论没有其他评论。 例子VBA: Sub Example_ColorBookPath()
'This example changes the color book path
'and then sets it to its original string
Dim pref As AutoCAD.AcadPreferencesFiles
Set pref = AcadApplication.Preferences.Files
Dim defCBPath As String
Dim changedCBPath As String
defCBPath = pref.ColorBookPath
MsgBox "The current color book path is " & defCBPath
pref.ColorBookPath = "c:\winnt;c:\temp"
changedCBPath = pref.ColorBookPath
MsgBox "The changed color book path is " & changedCBPath
pref.ColorBookPath = defCBPath
可视化 LISP: (vl-load-com)
(defun c:Example_ColorBookPath()
;; This example changes the color book path
;; and then sets it to its original string
(setq pref (vla-get-Files (vla-get-Preferences acadObj)))
(setq defCBPath (vla-get-ColorBookPath pref))
(alert (strcat "The current color book path is " defCBPath))
(vla-put-ColorBookPath pref "c:\\winnt;c:\\temp")
(setq changedCBPath (vla-get-ColorBookPath pref))
(alert (strcat "The changed color book path is " changedCBPath))
(vla-put-ColorBookPath pref defCBPath)
GMT+8, 2026-12-1 04:23
