Color 属性 (ActiveX)
指定对象或图层的颜色。 支持的平台:仅限 Windows 签名VBA: object.Color 属性值只读:否(只写对象除外)Group 类型:枚举acColor 默认颜色名称为 。使用介于 0 到 256 之间的颜色索引号,或此处列出的常量之一:acByLayer
言论对于大多数图形对象,此属性已过时,将在将来的版本中相应地删除。使用此属性时,可以设置颜色并将其读取为介于 0 到 256 之间的数字索引值。为标准七种颜色以及 BYBLOCK 和 BYLAYER 名称提供了常量。 如果使用 ,AutoCAD 将以默认颜色(白色或黑色,具体取决于您的配置)绘制新对象,直到它们被分组到块中。在图形中插入块时,块中的对象将继承颜色属性的当前设置。acByBlock 如果使用 ,则新对象将采用绘制它们的图层的颜色。该值对对象无效。acByLayeracByLayerLayer 例子VBA: Sub Example_Color()
' This example creates a polyline and colors it red.
' It then displays the current color setting for the polyline.
Dim plineObj As AcadPolyline
Dim currentcolor As Variant
' Create Polyline
Dim points(8) As Double
points(0) = 3: points(1) = 7: points(2) = 0
points(3) = 9: points(4) = 2: points(5) = 0
points(6) = 3: points(7) = 5: points(8) = 0
Set plineObj = ThisDrawing.ModelSpace.AddPolyline(points)
' First set the color of the object to Red
plineObj.Color = acRed
ThisDrawing.Regen (True)
' Now retrieve and display the Color property
currentcolor = plineObj.Color
' Translate the color from a number into text
If currentcolor = 256 Then
currentcolor = "By Layer"
Else
currentcolor = Choose(currentcolor + 1, "By Block", "Red", "Yellow", "Green", "Cyan", "Blue", "Magenta", "White")
End If
' Display
MsgBox "The Polyline color is: " & currentcolor, vbInformation, "Color Example"
可视化 LISP: (vl-load-com)
(defun c:Example_Color()
;; This example creates a polyline and colors it red.
;; It then displays the current color setting for the polyline.
;; Create Polyline
(setq points (vlax-make-safearray vlax-vbDouble '(0 . 8)))
(vlax-safearray-fill points '(3 7 0
9 2 0
3 5 0
(setq plineObj (vla-AddPolyline modelSpace points))
;; First set the color of the object to Red
(vla-put-Color plineObj acRed)
(vla-Regen doc :vlax-true)
;; Now retrieve and display the Color property
(setq currentcolor (vla-get-Color plineObj))
;; Translate the color from a number into text
(if (= currentcolor 256)
(setq currentcolor "ByLayer")
(setq currentcolor (cond
((= currentcolor 257) "ByBlock")
((= currentcolor 1) "Red")
((= currentcolor 2) "Yellow")
((= currentcolor 3) "Green")
((= currentcolor 4) "Cyan")
((= currentcolor 5) "Blue")
((= currentcolor 6) "Magenta")
((= currentcolor 7) "White/Black")
("Other")
;; Display
(alert (strcat "The Polyline color is: " currentcolor))
GMT+8, 2026-10-27 11:13
