CenterType 属性 (ActiveX)
2024-5-18 18:33| 发布者: admin| 查看: 721| 评论: 0|原作者: admin|来自: AutoCAD
指定径向尺寸和直径尺寸的中心标记类型。
object.CenterType
类型:DimDiametric、DimRadial、DimRadialLarge
此属性应用于的对象。
只读:不
类型:枚举acDimCenterType
  • acCenterMark
  • acCenterLine
  • acCenterNone
仅当将尺寸线放置在圆或圆弧之外时,中心标记才可见。
注意:此属性将覆盖给定维度的 DIMCEN 系统变量的值。
Sub Example_CenterType()
    ' This example creates a diametric dimension in model space.
    ' It then changes the type of center for the dimension.
    Dim dimObj As AcadDimDiametric
    Dim chordPoint(0 To 2) As Double
    Dim farChordPoint(0 To 2) As Double
    Dim leaderLength As Double
    ' Define the dimension
    chordPoint(0) = 5#: chordPoint(1) = 3#: chordPoint(2) = 0#
    farChordPoint(0) = 5#: farChordPoint(1) = 5#: farChordPoint(2) = 0#
    leaderLength = 1#
    ' Create the diametric dimension in model space
    Set dimObj = ThisDrawing.ModelSpace.AddDimDiametric(chordPoint, farChordPoint, leaderLength)
    ZoomAll
    ' Set the center to be none
    dimObj.CenterType = acCenterNone
    dimObj.Update
    MsgBox "The dimension center type is set to none."
    ' Change the center type to center mark
    dimObj.CenterType = acCenterMark
    dimObj.Update
    MsgBox "The dimension center type is set to center mark."
    ' Change the center type to center line
    dimObj.CenterType = acCenterLine
    dimObj.Update
    MsgBox "The dimension center type is set to center line."
(defun c:Example_CenterType()
    ;; This example creates a diametric dimension in model space.
    ;; It then changes the type of center for the dimension.
    ;; Define the dimension
    (setq chordPoint (vlax-3d-point 5 3 0)
          farChordPoint (vlax-3d-point 5 5 0)
          leaderLength 1)
    ;; Create the diametric dimension in model space
    (setq dimObj (vla-AddDimDiametric modelSpace chordPoint farChordPoint leaderLength))
    (vla-ZoomAll acadObj)
    ;; Set the center to be none
    (vla-put-CenterType dimObj acCenterNone)
    (vla-Update dimObj)
    (alert "The dimension center type is set to none.")
    ;; Change the center type to center mark
    (vla-put-CenterType dimObj acCenterMark)
    (vla-Update dimObj)
    (alert "The dimension center type is set to center mark.")
    ;; Change the center type to center line
    (vla-put-CenterType dimObj acCenterLine)
    (vla-Update dimObj)
    (alert "The dimension center type is set to center line.")
GMT+8, 2026-10-17 22:56
