Block 属性 (ActiveX)
2024-5-18 18:33| 发布者: admin| 查看: 949| 评论: 0|原作者: admin|来自: AutoCAD
Block 属性 (ActiveX)
指定与布局或多引线样式关联的块。
object.Block
类型:Layout、MLeaderStyle
此属性应用于的对象。
属性值 - 布局
只读:是的
类型:块
与布局关联的块。
属性值 - MLeaderStyle
只读:不
类型:字符串
MLeaderStyle 块 ID。
Sub Example_LayoutBlock()
    ' This example finds the name of the block associated with a layout.
    Dim xBlock As AcadBlock
    Set xBlock = ThisDrawing.ActiveLayout.Block
    MsgBox "The active layout corresponds to block: " & xBlock.name
(defun c:Example_LayoutBlock()
    ;; This example finds the name of the block associated with a layout.
    (setq xBlock (vla-get-Block (vla-get-ActiveLayout doc)))
    (alert (strcat "The active layout corresponds to block: " (vla-get-Name xBlock)))
GMT+8, 2026-11-30 12:08
