AutoSnapToolTip 属性 (ActiveX)
切换 AutoSnap 工具提示。 支持的平台:仅限 Windows 属性值只读:不 类型:布尔
言论此属性的初始值为 。True 注意:此属性的值存储在 AUTOSNAP 系统变量中。
例子VBA: Sub Example_AutoSnapToolTip()
' This example reads and modifies the preference value that controls
' the AutoSnap tooltips. When finished, this example resets the
' preference value back to its original value.
Dim ACADPref As AcadPreferencesDrafting
' Get the drafting preferences object
Set ACADPref = ThisDrawing.Application.preferences.Drafting
originalValue = ACADPref.AutoSnapTooltip
MsgBox "The AutoSnapToolTip preference is set to: " & originalValue
' Modify the AutoSnapToolTip preference by toggling the value
ACADPref.AutoSnapTooltip = Not (originalValue)
newValue = ACADPref.AutoSnapTooltip
MsgBox "The AutoSnapToolTip preference has been set to: " & newValue
' this preference in effect
ACADPref.AutoSnapTooltip = originalValue
MsgBox "The AutoSnapToolTip preference was reset back to: " & originalValue
可视化 LISP: (vl-load-com)
(defun c:Example_AutoSnapToolTip()
;; This example reads and modifies the preference value that controls
;; the AutoSnap tooltips. When finished, this example resets the
;; preference value back to its original value.
;; Get the drafting preferences object
(setq ACADPref (vla-get-Drafting preferences))
(setq originalValue (vla-get-AutoSnapTooltip ACADPref))
(alert (strcat "The AutoSnapToolTip preference is set to: " (if (= originalValue :vlax-true) "True" "False")))
;; Modify the AutoSnapToolTip preference by toggling the value
(vla-put-AutoSnapTooltip ACADPref (if (= originalValue :vlax-true) :vlax-false :vlax-true))
(setq newValue (vla-get-AutoSnapTooltip ACADPref))
(alert (strcat "The AutoSnapToolTip preference has been set to: " (if (= newValue :vlax-true) "True" "False")))
;; this preference in effect
(vla-put-AutoSnapTooltip ACADPref originalValue)
(alert (strcat "The AutoSnapToolTip preference was reset back to: " (if (= originalValue :vlax-true) "True" "False")))
GMT+8, 2026-11-29 10:47
