AutoSnapMarkerColor 属性 (ActiveX)
2024-5-18 18:32| 发布者: admin| 查看: 764| 评论: 0|原作者: admin|来自: AutoCAD
指定 AutoSnap 标记的颜色。
object.AutoSnapMarkerColor
类型:首选项起草
此属性应用于的对象。
只读:不
类型:枚举acColor
  • acRed
  • acYellow
  • acGreen
  • acCyan
  • acBlue
  • acMagenta
  • acWhite
此属性的初始值为 。acYellow
Sub Example_AutoSnapMarkerColor()
    ' This example reads and modifies the preference value that controls
    ' the color of the AutoSnap marker. When finished, this example resets
    ' the preference value back to its original value.
    Dim ACADPref As AcadPreferencesDrafting
    ' Get the drafting preferences object
    Set ACADPref = ThisDrawing.Application.preferences.Drafting
    originalValue = ACADPref.AutoSnapMarkerColor
    MsgBox "The AutoSnapMarkerColor preference is: " & originalValue
    ' Modify the AutoSnapMarkerColor preference by setting it to red
    ACADPref.AutoSnapMarkerColor = acRed
    newValue = ACADPref.AutoSnapMarkerColor
    MsgBox "The AutoSnapMarkerColor preference has been set to: " & newValue
    '         this preference in effect
    ACADPref.AutoSnapMarkerColor = originalValue
    MsgBox "The AutoSnapMarkerColor preference was reset back to: " & originalValue
(defun c:Example_AutoSnapMarkerColor()
    ;; This example reads and modifies the preference value that controls
    ;; the color of the AutoSnap marker. When finished, this example resets
    ;; the preference value back to its original value.
    ;; Get the drafting preferences object
    (setq ACADPref (vla-get-Drafting preferences))
    (setq originalValue (vla-get-AutoSnapMarkerColor ACADPref))
    (alert (strcat "The AutoSnapMarkerColor preference is: " (itoa originalValue)))
    ;; Modify the AutoSnapMarkerColor preference by setting it to red
    (vla-put-AutoSnapMarkerColor ACADPref acRed)
    (setq newValue (vla-get-AutoSnapMarkerColor ACADPref))
    (alert (strcat "The AutoSnapMarkerColor preference has been set to: " (itoa newValue)))
    ;;         this preference in effect
    (vla-put-AutoSnapMarkerColor ACADPref originalValue)
    (alert (strcat "The AutoSnapMarkerColor preference was reset back to: " (itoa originalValue)))
GMT+8, 2026-10-28 18:11
