AutoSnapMarker 属性 (ActiveX)
2024-5-18 18:32| 发布者: admin| 查看: 1092| 评论: 0|原作者: admin|来自: AutoCAD
切换 AutoSnap 标记。
object.AutoSnapMarker
类型:首选项起草
此属性应用于的对象。
只读:不
类型:布尔
  • True:启用 AutoSnap 标记。
  • False:禁用 AutoSnap 标记。
此属性的初始值为 True。
注意:此属性的值存储在 AUTOSNAP 系统变量中。
Sub Example_AutoSnapMarker()
    ' This example reads and modifies the preference value that controls
    ' the AutoSnap marker.  When finished, this example resets the
    ' preference value back to its original value.
    Dim ACADPref As AcadPreferencesDrafting
    ' Get the drafting preferences object
    Set ACADPref = ThisDrawing.Application.preferences.Drafting
    originalValue = ACADPref.AutoSnapMarker
    MsgBox "The AutoSnapMarker preference is set to: " & originalValue
    ' Modify the AutoSnapMarker preference by toggling the value
    ACADPref.AutoSnapMarker = Not (originalValue)
    newValue = ACADPref.AutoSnapMarker
    MsgBox "The AutoSnapMarker preference has been set to: " & newValue
    '         this preference in effect
    ACADPref.AutoSnapMarker = originalValue
    MsgBox "The AutoSnapMarker preference was reset back to: " & originalValue
(defun c:Example_AutoSnapMarker()
    ;; This example reads and modifies the preference value that controls
    ;; the AutoSnap marker.  When finished, this example resets the
    ;; preference value back to its original value.
    ;; Get the drafting preferences object
    (setq ACADPref (vla-get-Drafting preferences))
    (setq originalValue (vla-get-AutoSnapMarker ACADPref))
    (alert (strcat "The AutoSnapMarker preference is set to: " (if (= originalValue :vlax-true) "True" "False")))
    ;; Modify the AutoSnapMarker preference by toggling the value
    (vla-put-AutoSnapMarker ACADPref (if (= originalValue :vlax-true) :vlax-false :vlax-true))
    (setq newValue (vla-get-AutoSnapMarker ACADPref))
    (alert (strcat "The AutoSnapMarker preference has been set to: " (if (= newValue :vlax-true) "True" "False")))
    ;;         this preference in effect
    (vla-put-AutoSnapMarker ACADPref originalValue)
    (alert (strcat "The AutoSnapMarker preference was reset back to: " (if (= originalValue :vlax-true) "True" "False")))
GMT+8, 2026-11-29 10:54
