AutoSnapAperture 属性 (ActiveX)
2024-5-18 18:32| 发布者: admin| 查看: 675| 评论: 0|原作者: admin|来自: AutoCAD
切换 AutoSnap 光圈的显示。
object.AutoSnapAperture
类型:首选项起草
此属性应用于的对象。
只读:不
类型:布尔
  • True:显示自动捕捉光圈。
  • False:隐藏 AutoSnap 光圈。
此属性的初始值为 。True
当您捕捉到对象时,AutoSnap 光圈显示在十字准线的中心。仅当启用了 AutoSnap 标记、磁贴或工具提示时,此选项才可用。
注意:此属性的值存储在 APBOX 系统变量中。
Sub Example_AutoSnapAperture()
    ' This example reads and modifies the preference value that controls
    ' the display of the AutoSnap aperture.
    ' When finished, this example resets the preference value back to
    ' its original value.
    Dim ACADPref As AcadPreferencesDrafting
    ' Get the drafting preferences object
    Set ACADPref = ThisDrawing.Application.preferences.Drafting
    originalValue = ACADPref.AutoSnapAperture
    MsgBox "The AutoSnapAperture preference is set to: " & originalValue
    ' Modify the AutoSnapAperture preference by toggling the value
    ACADPref.AutoSnapAperture = Not (originalValue)
    newValue = ACADPref.AutoSnapAperture
    MsgBox "The AutoSnapAperture preference has been set to: " & newValue
    '         this preference in effect
    ACADPref.AutoSnapAperture = originalValue
    MsgBox "The AutoSnapAperture preference was reset back to: " & originalValue
(defun c:Example_AutoSnapAperture()
    ;; This example reads and modifies the preference value that controls
    ;; the display of the AutoSnap aperture.
    ;; When finished, this example resets the preference value back to
    ;; its original value.
    ;; Get the drafting preferences object
    (setq ACADPref (vla-get-Drafting preferences))
    (setq originalValue (vla-get-AutoSnapAperture ACADPref))
    (alert (strcat "The AutoSnapAperture preference is set to: " (if (= originalValue :vlax-true) "True" "False")))
    ;; Modify the AutoSnapAperture preference by toggling the value
    (vla-put-AutoSnapAperture ACADPref (if (= originalValue :vlax-true) :vlax-false :vlax-true))
    (setq newValue (vla-get-AutoSnapAperture ACADPref))
    (alert (strcat "The AutoSnapAperture preference has been set to: " (if (= newValue :vlax-true) "True" "False")))
    ;;         this preference in effect
    (vla-put-AutoSnapAperture ACADPref originalValue)
    (alert (strcat "The AutoSnapAperture preference was reset back to: " (if (= originalValue :vlax-true) "True" "false")))
GMT+8, 2026-11-25 15:28
