AutoSavePath 属性 (ActiveX)
2024-5-18 18:32| 发布者: admin| 查看: 775| 评论: 0|原作者: admin|来自: AutoCAD
指定使用属性启用自动保存时创建的文件的路径。AutoSaveInterval
object.AutoSavePath
类型:PreferencesFiles
此属性应用于的对象。
只读:不
类型:字符串
自动保存文件的驱动器和路径。
注意:此属性的值存储在 SAVEFILEPATH 系统变量中。
Sub Example_AutoSavePath()
    ' AutoSavePath. It then changes the value, and finally
    Dim currAutoSavePath As String
    Dim newAutoSavePath As String
    Set preferences = ThisDrawing.Application.preferences
    ' Retrieve the current AutoSavePath value
    currAutoSavePath = preferences.Files.AutoSavePath
    If currAutoSavePath = "" Then
        MsgBox "AutoSavePath is not currently set.", vbInformation, "AutoSavePath Example"
    Else
        MsgBox "The current value for AutoSavePath is " & currAutoSavePath, vbInformation, "AutoSavePath Example"
    End If
    ' Change the value for AutoSavePath
    newAutoSavePath = "C:\AutoCAD\"
    preferences.Files.AutoSavePath = newAutoSavePath
    MsgBox "The new value for AutoSavePath is " & newAutoSavePath, vbInformation, "AutoSavePath Example"
    ' Reset AutoSavePath to its original value
    preferences.Files.AutoSavePath = currAutoSavePath
        MsgBox "AutoSavePath is reset to Null.", vbInformation, "AutoSavePath Example"
    Else
        MsgBox "The AutoSavePath value is reset to " & currAutoSavePath, vbInformation, "AutoSavePath Example"
    End If
(defun c:Example_AutoSavePath()
    ;; AutoSavePath. It then changes the value, and finally
    ;; Retrieve the current AutoSavePath value
    (setq currAutoSavePath (vla-get-AutoSavePath (vla-get-Files preferences)))
    (if (= currAutoSavePath "")
        (alert "AutoSavePath is not currently set.")
        (alert "The current value for AutoSavePath is " currAutoSavePath)
    ;; Change the value for AutoSavePath
    (setq newAutoSavePath "C:\\AutoCAD\\")
    (vla-put-AutoSavePath (vla-get-Files preferences) newAutoSavePath)
    (alert (strcat "The new value for AutoSavePath is " newAutoSavePath))
    ;; Reset AutoSavePath to its original value
    (vla-put-AutoSavePath (vla-get-Files preferences) currAutoSavePath)
        (alert "AutoSavePath is reset to Null.")
        (alert (strcat "The AutoSavePath value is reset to " currAutoSavePath))
GMT+8, 2026-10-27 22:41
