AutoSaveInterval 属性 (ActiveX)
2024-5-18 18:32| 发布者: admin| 查看: 894| 评论: 0|原作者: admin|来自: AutoCAD
指定自动保存间隔(以分钟为单位)。
object.AutoSaveInterval
类型:PreferencesOpenSave
此属性应用于的对象。
只读:不
类型:整数
0 >= 自动保存间隔 <= 600
等于 0 的间隔将禁用自动保存。
大于 0 的间隔会自动以指定的间隔保存图形。
此属性的初始设置为 120。
对图形进行更改后,计时器将立即启动。每当保存图形时,它就会重置并重新启动。除非使用该属性指定了其他名称,否则当前图形将保存为 auto.sv$。AutoSavePath
注意:此属性也由 SAVETIME 系统变量控制。ISAVEBAK 系统变量(使用属性设置)可提高增量保存的速度,尤其是对于较大的图形。ISAVEPERCENT 系统变量(使用该属性设置)确定图形中允许的浪费空间量。CreateBackupIncrementalSavePercent
Sub Example_AutoSaveInterval()
    ' AutoSaveInterval. It then changes the value, and finally
    Dim currAutoSaveInterval As Integer
    Dim newAutoSaveInterval As Integer
    Set preferences = ThisDrawing.Application.preferences
    ' Retrieve the current AutoSaveInterval value
    currAutoSaveInterval = preferences.OpenSave.AutoSaveInterval
    MsgBox "The current value for AutoSaveInterval is " & currAutoSaveInterval, vbInformation, "AutoSaveInterval Example"
    ' Change the value for AutoSaveInterval
    If currAutoSaveInterval = 0 Then
        newAutoSaveInterval = 10
    Else
        newAutoSaveInterval = 0
    End If
    preferences.OpenSave.AutoSaveInterval = newAutoSaveInterval
    MsgBox "The new value for AutoSaveInterval is " & newAutoSaveInterval, vbInformation, "AutoSaveInterval Example"
    ' Reset AutoSaveInterval to its original value
    preferences.OpenSave.AutoSaveInterval = currAutoSaveInterval
    MsgBox "The AutoSaveInterval value is reset to " & currAutoSaveInterval, vbInformation, "AutoSaveInterval Example"
(defun c:Example_AutoSaveInterval()
    ;; AutoSaveInterval. It then changes the value, and finally
    ;; Retrieve the current AutoSaveInterval value
    (setq currAutoSaveInterval (vla-get-AutoSaveInterval (vla-get-OpenSave preferences)))
    (alert (strcat "The current value for AutoSaveInterval is " (itoa currAutoSaveInterval)))
    ;; Change the value for AutoSaveInterval
    (if (= currAutoSaveInterval 0)
        (setq newAutoSaveInterval 10)
        (setq newAutoSaveInterval 0)
    (vla-put-AutoSaveInterval (vla-get-OpenSave preferences) newAutoSaveInterval)
    (alert (strcat "The new value for AutoSaveInterval is " (itoa newAutoSaveInterval)))
    ;; Reset AutoSaveInterval to its original value
    (vla-put-AutoSaveInterval (vla-get-OpenSave preferences) currAutoSaveInterval)
    (alert (strcat "The AutoSaveInterval value is reset to " (itoa currAutoSaveInterval)))
GMT+8, 2026-10-17 14:35
