ArrowheadSize 属性 (ActiveX)
2024-5-18 18:32| 发布者: admin| 查看: 847| 评论: 0|原作者: admin|来自: AutoCAD
指定标注线箭头、引线和引线箭头以及钩线的大小。
object.ArrowheadSize
类型:Dim3PointAngular、DimAligned、DimAngular、DimArcLength、DimDiametric、DimOrdinate、DimRadial、DimRadialLarge、DimRotated、Leader、MLeader、MLeaderLeader
此属性应用于的对象。
只读:不
类型:双
箭头的大小必须指定为正实数 >= 0.0。
此属性的初始值为 0.1800。
箭头大小的倍数决定了尺寸线和文本是否应适合扩展线之间。如果由 DIMBLK 设置,则此属性还用于缩放箭头块。当 DIMTSZ 不是零时,此属性不起作用。
注意:此属性将覆盖给定维度的 DIMASZ 系统变量的值。
Sub Example_ArrowHeadSize()
    ' This example creates a Dim3PointAngular object in model space
    ' and then alters the visible appearance (size) of its arrowheads
    ' using the ArrowHeadSize property
    Dim DimPointAngularObj As AcadDim3PointAngular
    Dim AngleVertex(0 To 2) As Double
    Dim FirstPoint(0 To 2) As Double, SecondPoint(0 To 2) As Double
    Dim TextPoint(0 To 2) As Double
    ' Define the new Dim3PointAngular object
    AngleVertex(0) = 0: AngleVertex(1) = 0: AngleVertex(2) = 0
    FirstPoint(0) = 2: FirstPoint(1) = 2: FirstPoint(2) = 0
    SecondPoint(0) = 1: SecondPoint(1) = 4: SecondPoint(2) = 0
    TextPoint(0) = 6: TextPoint(1) = 6: TextPoint(2) = 0
    ' Create the new Dim3PointAngular object in model space
    Set DimPointAngularObj = ThisDrawing.ModelSpace.AddDim3PointAngular(AngleVertex, FirstPoint, SecondPoint, TextPoint)
    ' Read and display current arrowhead size
    MsgBox "The arrowhead size for this object is currently set to: " & DimPointAngularObj.ArrowheadSize
    ' Alter the arrowhead size property for this object
    DimPointAngularObj.ArrowheadSize = 0.5
    ' Read and display new arrowhead size setting
    MsgBox "The arrowhead size for this object is now set to: " & DimPointAngularObj.ArrowheadSize
(defun c:Example_ArrowHeadSize()
    ;; This example creates a Dim3PointAngular object in model space
    ;; and then alters the visible appearance (size) of its arrowheads
    ;; using the ArrowHeadSize property
    ;; Define the new Dim3PointAngular object
    (setq AngleVertex (vlax-3d-point 0 0 0)
          FirstPoint (vlax-3d-point 2 2 0)
          SecondPoint (vlax-3d-point 1 4 0)
          TextPoint (vlax-3d-point 6 6 0))
    ;; Create the new Dim3PointAngular object in model space
    (setq DimPointAngularObj (vla-AddDim3PointAngular modelSpace AngleVertex FirstPoint SecondPoint TextPoint))
    (vla-ZoomAll acadObj)
    ;; Read and display current arrowhead size
    (alert (strcat "The arrowhead size for this object is currently set to: " (rtos (vla-get-ArrowheadSize DimPointAngularObj) 2)))
    ;; Alter the arrowhead size property for this object
    (vla-put-ArrowheadSize DimPointAngularObj 0.5)
    ;; Read and display new arrowhead size setting
    (alert (strcat "The arrowhead size for this object is now set to: " (rtos (vla-get-ArrowheadSize DimPointAngularObj) 2)))
GMT+8, 2026-11-29 23:45
