AltUnitsScale 属性 (ActiveX)
2024-5-18 18:32| 发布者: admin| 查看: 816| 评论: 0|原作者: admin|来自: AutoCAD
指定备用单位的比例因子。
object.AltUnitsScale
类型:DimAligned、DimArcLength、DimDiametric、DimOrdinate、DimRadial、DimRadialLarge、DimRotated
此属性应用于的对象。
只读:不
类型:双
应用于备用单位的比例因子。
如果该属性处于打开状态,则此属性会将线性尺寸乘以一个因子,以在备用度量系统中生成一个值。初始值表示以英寸为单位的毫米数。AltUnits
该属性的初始值为 25.4000。
注意:此属性将覆盖给定维度的 DIMALTF 系统变量的值。
Sub Example_AltUnitsScale()
    ' uses AltUnitsScale to cycle through some common scales
    ' for the alternate dimension
    Dim dimObj As AcadDimAligned
    ' Define the dimension
    point1(0) = 0: point1(1) = 5: point1(2) = 0
    point2(0) = 5: point2(1) = 5: point2(2) = 0
    ' Enable display of alternate units
    dimObj.AltUnits = True
    ' Cycle through some common dimension scales
    dimObj.AltUnitsScale = 1         ' Change scale to Inches
    MsgBox "The alternate dimension units are now set to inches"
    dimObj.AltUnitsScale = 25.4     ' Change scale to Millimeters (default)
    MsgBox "The alternate dimension units are now set to millimeters"
    dimObj.AltUnitsScale = 2.54      ' Change scale to Centimeters
    MsgBox "The alternate dimension units are now set to centimeters"
(defun c:Example_AltUnitsScale()
    ;; uses AltUnitsScale to cycle through some common scales
    ;; for the alternate dimension
    ;; Define the dimension
    (setq point1 (vlax-3d-point 0 5 0)
          point2 (vlax-3d-point 5 5 0)
    (vla-ZoomAll acadObj)
    ;; Enable display of alternate units
    (vla-put-AltUnits dimObj :vlax-true)
    ;; Cycle through some common dimension scales
    (vla-put-AltUnitsScale dimObj 1)         ;; Change scale to Inches
    (alert "The alternate dimension units are now set to inches.")
    (vla-put-AltUnitsScale dimObj 25.4)     ;; Change scale to Millimeters (default)
    (alert "The alternate dimension units are now set to millimeters.")
    (vla-put-AltUnitsScale dimObj 2.54)      ;; Change scale to Centimeters
    (alert "The alternate dimension units are now set to centimeters.")
GMT+8, 2026-10-17 21:39
