AltToleranceSuppressZeroFeet 属性 (ActiveX)
2024-5-18 18:32| 发布者: admin| 查看: 934| 评论: 0|原作者: admin|来自: AutoCAD
指定在备用公差值中隐含零英尺测量值。
object.AltToleranceSuppressZeroFeet
类型:DimAligned、DimArcLength、DimDiametric、DimOrdinate、DimRadial、DimRadialLarge、DimRotated
此属性应用于的对象。
只读:不
类型:布尔
  • True:禁止显示零英尺测量值。
  • False:不要禁止显示零英尺测量值。
此属性的初始值为 。False
注意:此属性将覆盖给定维度的 DIMALTTZ 系统变量的值。
Sub Example_AltToleranceSuppressZeroFeet()
   ' uses AltToleranceSuppressZeroFeet to suppress or view the display of
   ' zero feet in the alternate dimension tolerance display
    Dim dimObj As AcadDimAligned
    ' Define the dimension
    point1(0) = 0: point1(1) = 5: point1(2) = 0
    point2(0) = 5: point2(1) = 5: point2(2) = 0
    ' Set up alternate unit tolerance display
    dimObj.AltUnits = True
    dimObj.ToleranceDisplay = acTolLimits
    ' Set the dimension display to a style that works with AltToleranceSuppressZeroFeet
    dimObj.AltUnitsFormat = acDimLArchitectural
    dimObj.AltUnitsScale = 2    ' Set the alternate unit scale to be a multiple of 2
Toggle:
    Select Case MsgBox("Press OK to suppress or view the display of zero feet in the alternate dimension tolerance", vbOKCancel)
        Case vbOK
            ' Toggle the display of zero feet for the alternate dimension value
            dimObj.AltToleranceSuppressZeroFeet = Not (dimObj.AltToleranceSuppressZeroFeet)
        Case vbCancel
            Exit Sub
    End Select
    GoTo Toggle
(defun c:Example_AltToleranceSuppressZeroFeet()
    ;; uses AltToleranceSuppressZeroFeet to suppress or view the display of
    ;; zero feet in the alternate dimension tolerance display
    ;; Define the dimension
          point2 (vlax-3d-point 6.01 5 0)
    ;; Set up alternate unit tolerance display
    (vla-put-AltUnits dimObj :vlax-true)
    (vla-put-ToleranceDisplay dimObj acTolLimits)
    ;; Set the dimension display to a style that works with AltToleranceSuppressZeroFeet
    (vla-put-AltUnitsFormat dimObj acDimLArchitectural)
    (vla-put-AltUnitsScale dimObj 2)    ;; Set the alternate unit scale to be a multiple of 2
    (vla-ZoomAll acadObj)
    ;; Toggle the display of zero feet for the alternate dimension value
    (vla-put-AltToleranceSuppressZeroFeet dimObj (if (= (vla-get-AltToleranceSuppressZeroFeet dimObj) :vlax-true) :vlax-false :vlax-true))
    (alert "Suppression of zero feet in the alternate dimension tolerance toggled.")
    ;; Toggle the display of zero feet for the alternate dimension value back to previous state
    (alert "Suppression of zero feet in the alternate dimension tolerance toggled back.")
GMT+8, 2026-11-29 23:55
