AltToleranceSuppressTrailingZeros 属性 (ActiveX)
2024-5-18 18:32| 发布者: admin| 查看: 768| 评论: 0|原作者: admin|来自: AutoCAD
指定在备用容差值中隐含尾随零。
object.AltToleranceSuppressTrailingZeros
类型:DimAligned、DimArcLength、DimDiametric、DimOrdinate、DimRadial、DimRadialLarge、DimRotated
此属性应用于的对象。
只读:不
类型:布尔
  • True:在备用公差值中隐含尾随零。例如,12.5000 变为 12.5。
  • False:不要在备用公差值中隐含尾随零。
此属性的初始值为 。False
注意:此属性将覆盖给定维度的 DIMALTTZ 系统变量的值。
Sub Example_AltToleranceSuppressTrailingZeros()
   ' uses AltToleranceSuppressTrailingZeros to toggle the display of trailing zeros
   ' in the alternate dimension tolerance display
    Dim dimObj As AcadDimAligned
    ' Define the dimension
    point2(0) = 7: point2(1) = 5: point2(2) = 0
    ' Set up alternate unit tolerance display
    dimObj.AltUnits = True
    dimObj.ToleranceDisplay = acTolLimits
Toggle:
    Select Case MsgBox("Press OK to toggle the display of trailing zeros in the alternate dimension tolerance", vbOKCancel)
        Case vbOK
            ' Toggle the display of trailing zeros for the alternate dimension tolerance value
            dimObj.AltToleranceSuppressTrailingZeros = Not (dimObj.AltToleranceSuppressTrailingZeros)
        Case vbCancel
            Exit Sub
    End Select
    GoTo Toggle
(defun c:Example_AltToleranceSuppressTrailingZeros()
    ;; uses AltToleranceSuppressTrailingZeros to toggle the display of trailing zeros
    ;; in the alternate dimension tolerance display
    ;; Define the dimension
          point2 (vlax-3d-point 7 5 0)
    ;; Set up alternate unit tolerance display
    (vla-put-AltUnits dimObj :vlax-true)
    (vla-put-ToleranceDisplay dimObj acTolLimits)
    (vla-ZoomAll acadObj)
    ;; Toggle the display of trailing zeros for the alternate dimension tolerance value
    (vla-put-AltToleranceSuppressTrailingZeros dimObj (if (= (vla-get-AltToleranceSuppressTrailingZeros dimObj) :vlax-true) :vlax-false :vlax-true))
    (alert "Suppression of trailing zeros in the alternate dimension tolerance toggled.")
    ;; Toggle the display of trailing zeros for the alternate dimension tolerance value back to previous state
    (alert "Suppression of trailing zeros in the alternate dimension tolerance toggled back.")
GMT+8, 2026-11-30 11:06
